Big 3 Upgrade Questions
Old Jul 22, 2005 | 12:19 PM
artmcd88's Avatar
"You are just a puppet.."
Question Big 3 Upgrade Questions
I read about the "Big 3" upgrade and had a few questions...
The person who did the write-up I read said to leave the original OEM wiring in as well (after all electricity follows the path of least resistance). My question is, is this necessary? I'd ratehr replace the wires to give the engine bay a more clean look.
Also, When you upgrade the alternator to battery feed wire you should go through the fuse box to prevent battery explosion during a short. Must you go through the fuse box? Or can you just install an "in-line" fuse (don't know if thats the proper term) like the ones used on amp power lines near the battery?
Your answers are greatly appreciated!!
Old Jul 22, 2005 | 01:10 PM
artmcd88's Avatar
Also, if the alternator is rated at 105A for a TSX what should the rating be on the fuse I'd use? 110A?
Old Jul 22, 2005 | 01:37 PM
elduderino's Avatar
VP Electricity
1) I would lose the OEM wiring.
2) The fuse is to cover the ass of the writer. In all the years I've worked on cars I've never seen a fuse or fusible link on the battery/alternator lead. Besdies, you can't run that through the OEM Fuse Box. Routing the wire to a location where a fuse holder could be installed would actually subject the wire to more risk of damage/short than just going straight from the battery to the alternator.
3) No fuse. But since your fuse, if present, is there to protect against deadshorts, NOT against alternator output draw, I'd go like 200A. But that's just me...
Old Jul 22, 2005 | 03:07 PM
artmcd88's Avatar
yea the write-up i saw was not done on a TSX and it seemed like their OEM wiring went through a fuse box when it went from the alternator to the battery but they said an external fuse could be used and place it close to the battery end to protect the battery.
they seemed to know what they were doing but in the end it didnt look to pretty
i just plan on replacing the OEM wires with 4awg wire...do you think that will suffice or do you think i would want to use 1/0awg...it just seems so bulky
Old Jul 22, 2005 | 04:59 PM
elduderino's Avatar
VP Electricity
What's in there now? I expect 4Ga would give you a big jum up... but make sure you use the same on the ground side...
Old Jul 22, 2005 | 07:37 PM
artmcd88's Avatar
I think its 8 gage in there now...so yea... im thinking 2 gage or 4...the alternator is gonna be a pita to get to though......especially to remove OEM because Acura bundles a bunch of wires together after the power leaves the alternator
Old Jul 22, 2005 | 10:39 PM
elduderino's Avatar
VP Electricity
If it was easy anyone could do it : )
Old Jul 23, 2005 | 06:36 PM
artmcd88's Avatar
true
Old Jul 23, 2005 | 08:47 PM
optomos's Avatar
I=X - optomos
Ive seen someone use 1/0awg. Overkill IMO, but hey to each his own.
Old Jul 24, 2005 | 01:15 AM
dark inspire's Avatar
El Presidente
but it looks so damn good
Old Jul 25, 2005 | 07:43 AM
artmcd88's Avatar
the write-up i saw was 1/0 awg...looked kinda crappy imo...there were these three big thick blue wires running across the engine bay...wasn't an amazingly clean look
Old Jul 28, 2005 | 09:21 AM
optomos's Avatar
I=X - optomos
I hate blue power wire. Looks stupid for that purpose imo.
Old Jul 28, 2005 | 09:24 AM
El Presidente
i think it looks good w/red
Old Jul 29, 2005 | 09:31 PM
Madeline's Avatar
How many watts you planning to run. I would suggest 1/0 anyways. It won't hurt and it will be inplace just for any possible future upgrades. No you don't need to keep the factory wire. The writer did that because it could only help the current flow and let's be honest, he wasn't going for the cleanest look.
Old Jul 31, 2005 | 09:03 PM
artmcd88's Avatar
yea I understand the whole path of least resistance thing...my system will probably run at about 1000 watts but peak is 1400
ill be sure to keep the "big three" at least the same if not a bigger gage than the power for my amps
datadr
Sep 12, 2015 09:12 PM
MyGuti
Sep 12, 2015 06:52 PM
nuldabz
Sep 3, 2015 05:49 PM
