Best audio input option for tsx with navi?
Old Mar 1, 2006 | 08:32 PM
IneedaTSX's Avatar
I know its been discussed a million times.
But as of right now what is my best option to add audio inputs to my 05 tsx with navi?
I would like to keep the stock XM, but its not critical
Old Mar 2, 2006 | 05:19 AM
Jonesi's Avatar
Don't you have a aux input in your center console?
What do you need it for?
Old Mar 2, 2006 | 01:57 PM
Tsx536's Avatar
Rep'n Taxbrain.com
I'm guessing that he has an 04/05. You're correct though, the 06 TSX has an AUX input.
Old Mar 2, 2006 | 07:41 PM
ultragamma's Avatar
Just dont get blitzsafe. It works when it wants to, not when you want it to.
Old Mar 2, 2006 | 08:26 PM
IneedaTSX's Avatar
whats the other option besides blitzsafe, soundgate?
Old Mar 9, 2006 | 09:27 PM
fuckleberry's Avatar
try this:
http://www.logjamelectronics.com/piehon03pcson.html
Old Mar 9, 2006 | 09:40 PM
Tsx536's Avatar
Rep'n Taxbrain.com
^^ It says you can't keep XM with that one
Old Mar 9, 2006 | 09:45 PM
IneedaTSX's Avatar
Thanks for the info, I'll give up XM, I just want a quality piece of equipment....I just want to plug it in and be good....no problems
Old Mar 10, 2006 | 12:20 AM
forget about BlitzSafe ...I give up, I have heard enough complaints !
I also have a negative impression of BS in general based on how their site and forum is managed. so
Just placed order for this set:
P.I.E. - HON03-F/MM
P.I.E. - HON03/PC-SON
based on feedback from another 2004/Navi member
Anyone else using this and what is your TSX year ?
Old Mar 10, 2006 | 08:09 AM
dizzy1's Avatar
I did this with my 05, sounds great and was very cheap, no problems after months of use and no noise, sounds just like CD quality.
https://acurazine.com/forums/audio-video-electronics-navigation-22/pics-my-nav-conversion-tsx-318541/
Old Mar 10, 2006 | 12:20 PM
https://acurazine.com/forums/showthread.php?t=318541
you did what ?
I read your thread but don't see any reference to AUX input adaptor.
So which product did you go with P.I.E ? Blitzsafe ? SoundGate ?
Old Mar 10, 2006 | 04:42 PM
dizzy1's Avatar
If you have xm, you don't need any adapters. In the passenger kick panel is a connector from the xm box in the trunk. Their are 4 wires you need to tap. L+, L-, R+, R-. If you cut these wires, and wire a relay or relays(depending on what you buy) you can toggle between 2 inputs. I have it so no power to the relay allows the factory xm to pass thru the relay and into the factory harness. When power is activated to the relay, it disconnects the audio wires from the xm box and sends the audio signal from the other device to the factory harness. Your radio's display will still show xm even though the audio is from your DVD, MP3 or game system.
Ol'Dave
Sep 5, 2020 02:56 PM
cycdaniel
Dec 17, 2019 10:58 AM
CatalinaILX
ILX
Oct 27, 2015 02:56 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
