Battery/alternator drained???
Old Aug 31, 2002 | 01:49 AM
langjae's Avatar
do it yourself, !
So I start my engine so I can mess around with the radio and tune the amps, etc. Then when I'm done I do the usual rev so I can "recharge" the battery or whatever the hell thats supposed to do. Then when I let off on the gas the rmps drop loooowww and looks like it will almost stall. Then when I saw it I revved it again so that it wouldnt go dead. And it won't happen if I rev then let off the gas gently..only when I rev and take it off right away. Oh and the light flickers sometimes during this process...
Is this due to my batter or alternator? Am I draining too much power . Thanks for any help.
Old Aug 31, 2002 | 01:58 PM
StreetEffectz's Avatar
It could be either actually...although the alternator should keep the car running just fine with the battery DISCONNECTED, there is a circuit that feeds back through the battery and works in conjunction with the alternator...if you have a multimeter you can check voltage with the car running at idle, and when you rev the engine.
You might also want to check your intake (if you have one) as you might have vapor in it causing a funny idle.
Old Sep 1, 2002 | 01:12 PM
Buddha24's Avatar
8th Gear
Hmmmm...I heard this odd high pitch noise coming from my engine recently. I brought it back to the dealer (still under 3 month warranty) and they told me it was the alternator. It works fine they said, it just runs loud, a high pitched loud. Its free for me to replace, so I'm obviously going to do it. But...that noise might be the intake???
Old Sep 2, 2002 | 10:34 PM
langjae's Avatar
do it yourself, !
What kinda vapor? How do I get rid of it?
Old Sep 4, 2002 | 01:34 AM
Austin519's Avatar
langjae:
If your lights flicker I doubt it's vapor. I think it's probably electrical. Tell me what kind of audio setup you are running? The battery is only going to give you trouble starting...that's really it's only purpose anyway. The alternator would be the next thing, or a short somewhere. But say what you're running, and if you know how much current you're pulling.
Austin519
Old Sep 4, 2002 | 10:39 AM
langjae's Avatar
do it yourself, !
Just an dei 1100d for the subs and dei 500 for the speakers
0 guage wire..all the stock wires to the alternator and various grand wires were upgraded too.
Old Sep 4, 2002 | 01:07 PM
Austin519's Avatar
langjae:
And you havea 1F cap? Hmm. If your lights are dimming...I'm not sure. Off the top of my head I don't know how much power those amps suck...hmmm. Maybe try a second capacitor. I'm trying to avoid saying it's your alternator. Does it just dim at idle? If so...it's probably nothing more than your alternator not putting out enough power at idle. A good quick fix would be to grab a smaller alternator pulley, so the alternator spins faster. These can be had from places that carry pulleys, such as UR, or you can call up the same people I had rebuild my alternator, Ohio generator, and ask them how much it would be to get that pulley from them.
Austin519
MetalGearTypeS
Aug 29, 2016 08:28 PM
hpfiend
Sep 27, 2015 06:59 AM
Rcelestino93
Sep 23, 2015 10:01 PM
STL TL-S
Sep 23, 2015 08:52 PM
Padre
Sep 19, 2015 09:08 AM
