Gas tank drain plug
Old Sep 17, 2015 | 11:10 AM
Padre's Avatar
Gas tank drain plug
Hi, I have a 2001 acura tl and have to drain the gas tank very old gas. Does anyone have a diagram as to where the drain plug is?
Old Sep 17, 2015 | 03:00 PM
Skirmich's Avatar
Gas Tank drain plug? That is a new one!
AFAIK there isn´t a Gas Tank Drain Plug on any Honda what-so-ever, I believe not even on most modern cars.
I was aware of a Pressure release system in the fuel line near the EVAP Canister which can be used to drain the gas tank with the help of the fuel pump..
Old Sep 17, 2015 | 03:02 PM
Just drill a hole on the bottom...
better option would be grab a length of tubing and a pump and pump it all out from the gas insertion hole chamber.
Old Sep 17, 2015 | 08:10 PM
fsttyms1's Avatar
Open the trunk, remove the floor lining and you will see the panel to access the top of the gas tank to get to the fuel pump. You could siphon the gas out that way much easier than getting a hose stuck in the filler neck.
Old Sep 18, 2015 | 05:22 AM
MilwaukeeDave's Avatar
Accelerator pedal drains it eventually.
Old Sep 19, 2015 | 09:08 AM
musiclevelz5's Avatar
All of my Hondas I have, have a gas tank drain plug. I have not had to change out a TL fuel pump yet so I dont know if theres a drain plug on it but I would venture to guess that there is one.
Take off the plastic guard and look for a 17 mm bolt on the bottom. That would be the plug you need to remove.
Mike734
Dec 10, 2021 01:25 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
MetalGearTypeS
Aug 29, 2016 08:28 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
San Yasin
Sep 29, 2015 10:52 AM
