atten: experts, need help quick!
Old Sep 21, 2002 | 05:56 PM
23wt's Avatar
Mugen Racing Team
I just traded my old sub in for a Rockford Fosgate RFZ 3410 10" sub. It's 150 rms and 400 watt peak. I have only 3-4 days left to return my old amp to the store due to 30 day refund.... I am currently using the Kenwood 629S which is only 150 watt bridged... I was thinking of putting in more power to the subwoofer. I don't know whether to choose from the Rockford 200S or 300S amp... i need some expert advice on which amp i should use for the best output from the 10" Rockford sub....
Old Sep 21, 2002 | 07:45 PM
Nicky Pass's Avatar
Fuct in the hed!
You can never have too much.....you can always turn the gain down
Old Sep 21, 2002 | 07:53 PM
nokio's Avatar
exactly............. i made that mistake with my subs.........too little power
now i have to go waste my money on 4pumped's shitty chromed idmax's and a big amp j/k (thanks 4pumped!)
the moral of my tale is the more wattage, the better
Old Sep 21, 2002 | 08:54 PM
23wt's Avatar
Mugen Racing Team
from what you two have said.... should i stick to the 150W amp right now to power the Rockford or get a 200 or 300W to power it???
Old Sep 21, 2002 | 11:43 PM
Nicky Pass's Avatar
Fuct in the hed!
Keep the new sub and get the new amp.....if a sub is 150 rms 400 peak and you get a 300 watt amp......you can turn down the gain on the amp to get a CLEAN 150 watts......with room for improvement. Who knows, you may get a 12" or 2 10"s later on.
Old Sep 24, 2002 | 10:08 AM
23wt's Avatar
Mugen Racing Team
cool.... thanks man... i also found out that the Rockford 200M amp is a mono amp. It give 200@2ohms and 100@4ohms... so in conculsion.. does it mean that its only giving out 100W to the sub since the sub is impedence 4ohms??
whereas the Rockford 200S is a 2 chnl amp and bridgeable and gives 200@4ohms...
Which one should i go for? they both can be said the same having a max of 400W but one is mono and one is 2/1 chnl.
Old Sep 24, 2002 | 10:56 AM
shawhite_RENAMED's Avatar
the rockford amp would push this speaker just find..... just bridge it mono and it will push 200w to that speaker...
Old Sep 24, 2002 | 05:01 PM
23wt's Avatar
Mugen Racing Team
alright cool thanks man
4drviper
Apr 23, 2025 07:13 PM
knight rider
Mar 4, 2016 08:59 AM
KBTypeS
25
Oct 1, 2015 04:49 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
