Any 5.1 surround amps out there?
I'm aware of the Diamond Audio D65.2, 7 channel amp, which will handle a pair of fronts, rears, center channel, and sub, but it's on backorder. Is anyone aware of other amps that would handle all channels? I want one amp to handle everything.
The JL Audio E6450 is 6channels at 45w each though. I'm looking for an amp that handles 5 channels, plus one for the sub. The JBL may be a possiblity...just went to their site and glanced at the GTO755.6 II. It won't do the center channel though.
Originally Posted by jpswanberg
alpine has 2 5channel amps, just add your favorite mono sub amp and you're ready to go
Do you want an amp that can handle 6 channels, or that has a decoder internally?
Audison has one that can do 5.1 with an external decoder.
Phoenix has one with an internal decoder but it's not that good.
Channels: 7
RMS @ 4 Ohm: 60 x 5 & 70 x 2
RMS Mono: 280 x 1 @ 4 Ohm (Sub Only)
THD: 0.05%
Crossovers: Low Pass, High Pass, Subsonic
I'm trying to find something similar, in that it does 5 channels for the front, rear and center channels, and it will feed the subwoofer as well.
Originally Posted by glott
you're still going to need a decoder
more suggestions in here, i think
https://acurazine.com/forums/audio-video-electronics-navigation-22/mobile-theater-help-331887/
but i think he had a H701 as well....
OK, I read your sig, so you are retaining the HU in the current TL.
Two things:
1) audison makes one that will work.
2) There is significant EQing going on in that system that is not neccesarily 5.1 related.
3) I would seriously consider a Zapco 6-channel and a mono Digital Reference amp (put a brass heat sink resistor on the center channel, or just turn the gain WAYYYYY down). I think that reversing the EQing is more important than having it all in one chassis. The Digital Reference have 10-band Parametric EQs per channel, time alignment per channel, very flexible xovers, a seperate parametric bass adjustment, and the ability with the add on cable of accepting OEM balanced signals.
Two things:
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
