amp wiring...confusing as hell!
Old Jun 16, 2001 | 10:13 AM
Post amp wiring...confusing as hell!
ok i removed the back seat i exposed the stock amp....i wanna be able to disconnect the stock amp and reconnect an aftermarket amp and sub....
after taking the stock amp out i'm left with a bunch of wires....2 big green and orange wires....and the rest are normal red/yellow/orange...etc colors....what do i do?? all i want to do now is rewire it so it goes to my new amp...but i don't know ...
Old Jun 16, 2001 | 01:19 PM
Post
what's the remote wire for?
when u say under the rear deck...do you mean the wires behind the seat?
like before or after the stock sub?
cuz i see wires going into the stock sub and some wires going out...
do i have to remove the stock sub to cut the wires?
what do the + and - signal wires look like...
there's 4 green wires and 4 black wires and 1 orange 1 blue....and i have no idea which is which..
when all this
Old Jun 16, 2001 | 04:45 PM
AcuraTL's Avatar
OG
Post
If you do not know what remote turn-on wire is for, I really think you should pay a shop $45 to have them install it for you.
Honda-Acura.net TL Forum Moderator.
1999 Silver with factory body kit, spoiler and burlwood instrument cluster and shift knob. Joshua Tree Wood dash kit. Hella air horns. Tint all around. Razo competition pedals. MOMO Sport 18"X7.5" with 225/40ZR Pirelli P7000SS. Weapon-R intake. Comptech springs, exhaust and headers. Inspire Tailights, homemade ram-air and Polarg M-12 front turn signals. Comptech front and rear sway bar. Axxis Metal Master front and rear pads. Mugen front grille. 2 Polk/MOMO 10" subs, Orion Xtreme 500.4 amplifier and Alpine CD changer.
My AcuraTL Homepage
NEW: '01 Acura MDX Silver Premium
Front 35% tinted windows. Running boards. Roof rack. Tailgate deflector. Moonroof visor. Rear mud guards. Razo premium white headlight bulbs. PIAA yellow plasma ion fog bulbs. More to come later......
Old Jun 16, 2001 | 06:35 PM
Ex TL-S owner
Post
Guys......I have my pwr wire and ground wires set. I took out my rear seats and I took the BOSE amp out. So which one is the remote wire? I see a blue one and two orange wires. Does it matter where I splice em?
And for the stock sub, I disconnect the two ends (+,-) and I just connect the four wires to my AudioLink Lineout Converter? Please respond soon. My rear seats are out and I can't drive it till I'm done. Thanks in advance!
2002 TL TYPE S
SATIN SILVER/EBONY w/NAVI
BIRTHDAY: June 8, 2002
[img]http://albums.photopoint.com/j/View?u=1212504&a=8950241&p=50260985&Sequence=0&res =high
[/img]
Old Jun 16, 2001 | 06:50 PM
Post
HAHAHA...i'm in that EXACT situation that you are in!!!...haha i have my seats out ..the stock amp in on the floor...and my amp is just sitting there...
and i have no idea what goes where...heheh
anyway i'm just hoping that this forum can really help us....
good luck
Old Jun 16, 2001 | 11:10 PM
mr tl's Avatar
Post
brotha maaaaan
what your gonna do it get the + wire for your new amp from the battery
the - is ground. so you find a factory ground point and use that. there is one behind the plastic panel at the rear of the trunk
the remote wire is blue, or orange. i keep forgetting damn it. that wire is behind the back seat, at the factory amp
as for the signal wires, your going to look under the rear deck and tap into the - and + from there (going to the factory sub). make sure you dissconnect them
ya follow?
Follow as i ride
99 Satin Silver
Bridgestone RE-730 225/55/16
oem kit
ctech exhaust
ctech sways
aem intake
system
Old Jun 16, 2001 | 11:40 PM
AcuraTL's Avatar
OG
Post
I think one of you just emailed me and I just responded with an answer.
The blue one is the remote turn on wire. You take the signal going into the subwoofer and use that signal to your line-out converter. However, you CANNOT take out or disconnect ANY of the wires going into/out of the factory amp, or else, the signal going into the wires to the factory sub will not be there.
Old Jun 16, 2001 | 11:56 PM
Ex TL-S owner
Post
Thanks for the e-mail and this reply! I will give it a shot tomorrow. Thanks for your help!
2002 TL TYPE S
[/img]
Old Jun 17, 2001 | 12:18 AM
AcuraTL's Avatar
OG
Post
No problem dude, good luck. Email me if you have problems.
Old Jun 17, 2001 | 12:22 PM
Post
do you absolutely need an line out converter....
i'm just installing a sub and amp...that's all....
will need the LOC if i install the aftermarket amp after the stock amp (leaving both connected)??
how can i add an aftermarket sub and amp without using an LOC??
Old Jun 17, 2001 | 01:03 PM
Post
ok wait wait!...lemmie see if i got this right.....
if i wanna add an aftermarket sub and amp....
this is what i THINK i have to do
1) in thr trunk disconnect the stock sub from the car...those 2 little plugs...(the + and the -)
2) rip out the back seats..expose the stock amp
3) disconnect the stock amp(pull out the plug)
4) take the wires that are going towards the stock amp and cut em..( the pack of wires that have the thick brown wire etc..)
5) connect the signal for the sub to my amp..which are the wires i just cut...( i think they are the green and black ones with a singe stripe)
6) connect the remote ( blue or orange?)
7) connect the power for the amp directly to the battery with a fuse
8) hook up my aftermarket amp to my aftermarket sub
9) done?
please if i've done something wrong can u please tell me? or correct me it's very important...
Old Jun 17, 2001 | 05:30 PM
AcuraTL's Avatar
OG
Post
Dude, here it goes:
1st Run the power wire from the battery straight to the trunk of your car.
2nd Find a good ground in the trunk, scrape off the paint of a metal part in the trunk and connect the groud wire.
3rd Unplug the signals going into the factory sub and use those signals for your line-out converter.
4th Do not disconnect ANYTHING to the stock amplifier, just tap to the blue wire for remote turn-on for your amplifier.
Hope you know what you are doing. If you fry your eletrical system, you are fvcked.
Old Jun 17, 2001 | 06:27 PM
Post
THANKS ACURATL, you da man!!!!
but here's a another question...won't i blow my aftermarket sub if it's connected after the stock sub?
Old Jun 18, 2001 | 12:20 AM
AcuraTL's Avatar
OG
Post
You are not going to use the factory sub. You are merely going to use the signal from it to feed your amplifier so it gets the signal to your aftermarket sub.
Old Jun 21, 2001 | 12:10 PM
Ex TL-S owner
Post
I gave up after I took out my rear seats. I went to circuit city and they installed it for $75. It is definitely worth it! If they mess up, they will cover the cost. If you mess up, then you're f-ed. It defnitely wasn't worth all the time I wasted. I can do regular systems, but I would never do a BOSE system again!
The installer used the orange wire as a remote wire. He said that one will definitely keep my ALPINE V12 amp on. He said that some amps need more power to turn it on.
I also disconneted the stock sub and took it out. That way, the sub in my trunk can travel better through the opening.
Good luck!
2002 TL TYPE S
<IMG SRC="http://albums.photopoint.com/j/View?u=1212504&a=8950241&p=50260985&Sequence=0&res =high
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by CarFreak on June 21, 2001 @ ]</font>
Old Jun 21, 2001 | 05:50 PM
AcuraTL's Avatar
OG
Post
Glad to hear that you had your system done. Isn't the orange wire a constant 12v? Isn't your amplifier on all the time then?
Old Jun 21, 2001 | 07:32 PM
SimTypeS's Avatar
...and then there was One
Cool
Is the orange the power wire, then, if it is on all the time? Why the heck wouldn't it be red? Should just have red power, black ground, blue remote, and then the signal wires. Why would Bose make it so confusing? And, if you do take the signal wires out of the factory amp, and use them for your new amp, won't the factory amp still come on whenever you turn on the stereo, but just not have a signal? Is that smart to do? Why not unplug the remote wire, too? Sorry for all the questions, I just want to install my system, and started venting. :-) Oh, another one: If I wanted to have a multi-amp system, could I take the signal wires going into the factory amp, run them into an Audio Control EQX-2 crossover/eq? Probably too simple, and Bose would find a way for it not to work...
Play nice.
Old Jun 21, 2001 | 08:40 PM
Ex TL-S owner
Post
Nope....It only turns on when I turn on the radio,
2002 TL TYPE S
[/img]
Old Jun 25, 2001 | 01:01 AM
BirjuP's Avatar
Post
Do I have to take out the Back Seats to expose the bose amp?
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
