Amp Pre Out Question
Old Mar 21, 2005 | 10:00 PM
glott's Avatar
I have an 04 TSX with an Alpine MRD-M301 Amp pushing a single 12. I had the rear 6x9s tapped to the speaker level inputs on the amp. My question is, if I want to add an amp to run my mids and highs, can I use my current amp's pre out as the signal for the new amp. I think the answer is no because the 6x9s are crossed over, but I just wanted to make sure. Does this make sense to anyone??
Old Mar 21, 2005 | 10:38 PM
elduderino's Avatar
VP Electricity
Yes, it makes sense.
No, you can't do it.
Please see my post re: adding preouts to the OEM HU:
https://acurazine.com/forums/audio-video-electronics-navigation-22/instructions-install-shop-preamp-output-300209/
Old Mar 21, 2005 | 10:44 PM
glott's Avatar
Thanks, so if install it like you say would it be advisable to run the sub amp off the other amp's pre outs and remove the speaker taps? (ie. will it sound better/different)
Old Mar 21, 2005 | 11:21 PM
elduderino's Avatar
VP Electricity
Should sound a little cleaner and maybe go a little lower. Can't get any worse - speaker leve is the worst kind of signal there is.
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
06TLMatt
Oct 2, 2015 08:14 PM
Medinak12
Sep 23, 2015 07:11 PM
Pegon95
Sep 15, 2015 01:54 PM
datadr
Sep 12, 2015 09:12 PM
