amp installed... now no power??? help
Old Jan 23, 2003 | 08:06 PM
bjo3030's Avatar
I just completed installing an amp in my 03 tl-s but now my stock head unit won't turn on. I have power to the amp I know because its power light is on. In addition to the radio not powering on the 12v outlets in the front don't have power and the windows work but the auto up and down feature on the driver side don't. Please help me figure this one out...
thanks
Old Jan 23, 2003 | 08:30 PM
kent_99TL's Avatar
Speaker wire was short.
Old Jan 23, 2003 | 08:34 PM
bjo3030's Avatar
what do you mean...?
Old Jan 23, 2003 | 09:06 PM
kent_99TL's Avatar
You mean you have the amp installed, did you mean just all the power cable which is "red" main power(the one connect to the battery) "black" Ground cable and "blue" remote turn on? I need some more info how you did the amp install.
Old Jan 23, 2003 | 09:16 PM
bjo3030's Avatar
yes I have the amp totally installed.... remote wired to the fuse box, power to battery, remote tapped into the brown sheathed wires, and ground to the chassis... the amp gets power but the radio doesn't and won't turn on.... help!
Old Jan 23, 2003 | 09:24 PM
kent_99TL's Avatar
remove the remote turn on from your fuse box, I think you get a wrong remote turn on connection because your amp won't on if your HU did not turn on.
"remote tapped into the brown sheathed wires" do you mean your rca cable?
Old Jan 23, 2003 | 09:29 PM
bjo3030's Avatar
yeah rca's is what i meant from the brown sheath... I tapped the remote into a black wire with a yellow line down it in the fuse box... which one is acceptable?
Old Jan 23, 2003 | 09:36 PM
kent_99TL's Avatar
(1) I will remove the the remote turn on wire from the fuse box and see did it fix the problem first. Also double check did you blow up any fuse.........
(2) If you got all problem fix and I will tap the remote turn on wire to a "ORANGE" wire "before the bose amp" which is the remote turn on for the bose amp.
(3) Do you know which wire is + and - inside the brown shield twist pair?
Old Jan 23, 2003 | 09:43 PM
bjo3030's Avatar
ok well i'm gonna try tapping that wire by the amp for my remote... I don't know which one is + and which one -..... i heard that it doesn't matter....if changing the remote doesn't work i'll replace the fuse.... thanks for all your help Kent it is most appreciated
Old Jan 23, 2003 | 09:53 PM
kent_99TL's Avatar
Inside the brown shield (Blue/Green)+ / (orange/blue)-
On your Rca Jack the wire which is in the center post is + and on the outer post is - also make sure you have a good ground connection. Let me know if there anything else I can help.
Old Jan 23, 2003 | 11:33 PM
bjo3030's Avatar
ok so it turned out to be a blown fuse... now the radio is up and running and the amp is powered but the sub is not running... any clues on what the problem could be... i'm gonna check all my wiring again and hope it turns out
Old Jan 24, 2003 | 01:19 AM
Don't know about your sub problem. But the auto up/down window feature needs to be reset everytime the battery is disconnected. To reset the window function... read the owners manual. It's in there somewhere.
Old Jan 24, 2003 | 07:26 AM
kent_99TL's Avatar
Looks like you got the power connection right, did your amp turn off when you turn off your HU and turn on when you turn the HU back on?
Now the problem we looking at will be your signal wiring which include your RCA connection, speaker wire from the amp to the sub, also you need to check the user manual for your amp make sure you are not under "safe mode". Double check your wiring with the wire color for +/- I gave you from the pre post.
Old Jan 24, 2003 | 12:06 PM
bjo3030's Avatar
when i put the key in to the last position before turning the car on, the amp light comes on for a few seconds and then turns off.... when i turn the engine on the amp light comes on and stays on... turning the radio on and off does nothing to the amp's power... this is what i expected though as the remote is going to an ignition fuse... so now my amp turns on but thats about it, no sound from the sub?? any ideas
Old Jan 24, 2003 | 01:49 PM
kent_99TL's Avatar
(1)You should better use the orange wire before the stock amp for your remote turn on which allow you to turn on/off from your HU.
(2) Where did you connect your ground wire? on the chassic? Then you should sand down the paint to bare metal at that spot and put a lock washer on for a good connection, a lot of time a ground issue will give you a lot problem.
Old Jan 24, 2003 | 02:11 PM
bjo3030's Avatar
yeah I already sanded down when I did the ground... I will change the remote eventually, but as for right now I want to figure out why I can't get my sub/amp to work
Old Jan 24, 2003 | 02:31 PM
kent_99TL's Avatar
What kind of amp you have, because the signal you tapped in is mono. If you have a two channal amp you should use the left channl for signal input. BTW what sub you are using?
Old Jan 24, 2003 | 03:22 PM
bjo3030's Avatar
i'm using a orion xtreme 9002 which is 2 channel. i'm running it to 1 10" solobaric L7
Old Jan 24, 2003 | 08:08 PM
kent_99TL's Avatar
Check on the amp manual and see if there any thing you need to do on the amp if you only have mono input.
Old Jan 25, 2003 | 02:46 PM
bjo3030's Avatar
yeah i have it run the way it describes for mono... is there a way i can check the signal wires to see if they are working... i'm thinking that must be where the problem is, but i thought i did everything i was supposed to?
Old Jan 25, 2003 | 05:08 PM
kent_99TL's Avatar
Next thing I will do is check the sub volume setting on the amp turn it up to +6db and see.
Old Jan 25, 2003 | 07:01 PM
bjo3030's Avatar
well i have the gains all the way up and I get nothing from the sub so thats def. not it.... any ideas now, lol? i'm thinking its the signal wires not getting the signal... I don't know how to test that out, though?
Old Jan 25, 2003 | 08:21 PM
kent_99TL's Avatar
Well that what I am thinking too, can you tell me how you tap the rca wire to the signal wire behind the stock bose amp?
Old Jan 25, 2003 | 08:26 PM
bjo3030's Avatar
Basically I cut one end of RCA's off my RCA-RCA cable.... then I tapped the end of each RCA to each of two wires inside of the brown cable leading to the stock amp
Old Jan 25, 2003 | 08:28 PM
kent_99TL's Avatar
+/- did you follow the color I gave you? What tools you use to tap the wire?
Old Jan 25, 2003 | 08:33 PM
kent_99TL's Avatar
Okay after I read your post again......
Question: then I tapped the end of each RCA to each of two wires inside of the brown cable leading to the stock amp
You suppose to have (1) rca wire (not 1 pair, I mean just 1) after you cut the other end you should have two wire.
I assume you have a pair of rca cable which mean you have 4 wires tapped in the brown shield twist pair. Am I right? If I am correct disconnect either one rca connector from you amp and see anything thing happen.
Old Jan 25, 2003 | 08:44 PM
bjo3030's Avatar
I'm thinking maybe a Y-cable is the answer... I mean i tried hooking it up with only 1 of the rca endings in my amp and the other one unplugged but it still didn't work... with the y cable i could make those 2 rca endings into 1 and try it then
Old Jan 25, 2003 | 08:57 PM
kent_99TL's Avatar
I see. Here is my setup to give you some more idea.
Alpine MRD-300 mono amp, one rca cable tapped to brown shield twist pair (only one rca jack not one pair). I try with one rca jack plug in the left channel on the amp------ it works fine. Than I have a Y cable which split on rac to two and it works fine also but my amp have 1 or 2 channel setup allow you to choose.
In your case I see you bring out two rca connector from the brown shield twist pair, that mean both of them are mono, you can try to set your amp to mono and plug either one of the (two rca) connector to your amp on the left channel(usually the white one) remeber only one rca connector is connect to your amp.
Old Jan 26, 2003 | 12:57 AM
bjo3030's Avatar
okay let me understand what you're saying... you have a single rca plug running down that goes to each of the bose amp signal wires?
Old Jan 26, 2003 | 10:13 AM
kent_99TL's Avatar
Yes, two wires inside the brown shield (Blue\green) as + and (orange\blue) as - , one rca wire with one connector to your aftermarket amp and the other end you need to cut it off which gave you two wires also (centerpost +) (outerpost -) tapped it to the wires inside the brown shield in order of + and -.
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
knight rider
Mar 4, 2016 08:59 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
