Amp install on hold
Old Sep 5, 2002 | 08:38 PM
acur8ly's Avatar
Amp install on hold
I started my install today and had to leave the car at work. I started the install only to find out the amp install kit didn't have all the parts it said it had. I had to leave my baby in pieces.
Old Sep 5, 2002 | 10:45 PM
SilverKnight's Avatar
Retired. Not available.
Red Xs
Old Sep 6, 2002 | 06:11 AM
acur8ly's Avatar
Old Sep 6, 2002 | 03:04 PM
I think I see the print out from my template. Is that right?
Old Sep 6, 2002 | 09:29 PM
acur8ly's Avatar
You know it Silverknight template was used.
I screwed it up tho some how. The noise on the system is horrible, and when u accelerate u hear it louder. My rca cables are not even close to the power cables. I also used a line converter. Any ideas on how to kill the noise. The only good things, the install was super neat and I got a boost from my ecu being reset.
Old Sep 6, 2002 | 09:47 PM
You can go to a Radio Shack and ask for a ground loop isolator ($14.99). Plug it in, if it doesn't work, reverse it. If it still doesnt work, you wanna go with the converter-less approach. Repeat the process with the ground loop isolator if you got alternator noise (the whining when you accelerate).
Old Sep 6, 2002 | 10:08 PM
acur8ly's Avatar
ok will do that tomorrow thanks
Old Sep 6, 2002 | 11:01 PM
acur8ly's Avatar
My amp has rca imputs, if I remove the line converter what would be the best way to run the imputs?
Old Sep 7, 2002 | 02:05 AM
Tap RCA cables into the outputs from the head unit. They are already at line-level.
Old Sep 7, 2002 | 09:44 PM
acur8ly's Avatar
I got rid of the converter and tapped rca's from the head unit. That fixed the problem. Thanks
Old Sep 9, 2002 | 12:19 AM
Cool. Enjoy your system
Old Sep 9, 2002 | 12:44 AM
Nicky Pass's Avatar
Fuct in the hed!
Pics?
Old Sep 9, 2002 | 07:14 PM
acur8ly's Avatar
I just have it hooked up, not mounted and arranged yet, will post picks when done.
Silverknight: I remembered reading a post saying the + and - wires were crossed on one of channels, which one was that? The reason I ask is because my amp has 6 imput channels and 5 output channels, a left and right for the sub. when I put both a left and right on the sub it drops the volume in half. If I just run one of the channels to both the 5th and 6th imputs the sub kicks ass.
Old Sep 10, 2002 | 10:52 AM
I never said that. Some guy said that but he never tell us what he did to prove what he found.
Old Sep 10, 2002 | 01:16 PM
acur8ly's Avatar
ok what would cause a loss of power in the situation above?
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
Pegon95
Sep 15, 2015 01:54 PM
Sep 14, 2015 10:09 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
