Alarm system questions
Old Nov 10, 2008 | 11:46 PM
blondechick's Avatar
My alarm system has never had the chirp and my remote doesnt work. I dont know if its the system or the remote thats bad. I am trying to figure that out. Now the alarm has went off. Do you have to use the remote to get the alarm to make the chirp? Is there anyway to tell if its the remote or something else? Thanks.
Old Nov 11, 2008 | 12:18 AM
asianspec's Avatar
freebie for you (search is broken)
push and hold the trunk and lock buttons at the same time until the light blinks twice
Old Nov 11, 2008 | 01:34 AM
ty
Old Nov 11, 2008 | 06:24 AM
DoubleSh0t's Avatar
Did you change the battery in the remote?
Old Nov 11, 2008 | 09:19 AM
no but i went to change it and they tested it and told me its good. When you press the buttons the lights on the remote come on but you gotta press them really hard.
Old Nov 11, 2008 | 11:46 AM
Myxomatosis's Avatar
well, dont change the battery at the dealership, get the code off the battery and you can just buy one anywhere, the remote will pry apart easily with a sharp knife. This probably has nothing to do with the chirp, but it'll help your range. I cant think of a reason why pushing it really hard would be necessary unless the remote is busted up in some way. You sure you have to push hard or just push for a long time?
Old Nov 11, 2008 | 12:26 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
u may wanna take apart your remote and clean the contacts for the buttons
Old Nov 12, 2008 | 09:32 PM
Well since the remote didnt work when i got the car I decided to reprogram it. Well it actually works. The only problem i have now is the driver side door makes a noise. It sounds like the lock is free spining so basically it is a manual lock. Stinks i cant use the remote to lock the dorrs because of the messed up lock. At least i can pop my trunk and i actually heard the chirp. lol. Anyways I wasnt needing to press the remote hard just for a lil while. Thanks you to all.
Old Nov 13, 2008 | 09:28 AM
(Mid-Atlantic)
There's a diy on how to fix this in the diy/faq guide, your door lock actuator is busted
Old Nov 13, 2008 | 06:08 PM
ok thanks. ill see if i can figure it out. lol.
Feb 25, 2020 09:57 AM
heykosal
1G RDX Problems & Fixes
Sep 21, 2015 09:41 AM
datadr
Sep 12, 2015 09:12 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
