Aftermarket Head Unit - Factory Sub
Old Dec 20, 2004 | 09:18 AM
jsbtn's Avatar
I have been looking at possibly replacing the factory head unit in my 2000 TL. The ones that I've looked at (at Crutchfield) all state that the factory sub will not work with an aftermarket head unit. I'm assuming that this is simply due to the wiring harnesses. Is there a way to connect the factory sub to an aftermarket head unit or are there harnesses available to allow this?
Thanks,
JSB
Old Dec 20, 2004 | 10:01 AM
jthorne's Avatar
6th Gear
See this thread from last week.
I managed to successfully get the subwoofer working... sort of. Every time their was a break in the signal (power on, pause, skip song, etc.) it popped at full power. Less than ideal in my opinion, so after all that I ended up unplugging it.
Old Dec 20, 2004 | 11:36 AM
ou sig's Avatar
Boomer SOONER
dont even mess with it.
Old Dec 20, 2004 | 03:46 PM
jthorne's Avatar
6th Gear
Right. Good advice. I messed with it... now wish I hadn't.
Old Dec 20, 2004 | 07:27 PM
DerrickM's Avatar
Ditto. I had exactly the same results as jthorne--finally got it to work (by buying a $300 line driver), but the turn-on thump was deafening. (I'm not talking about a little pop you can ignore). I finally just bought a new sub/amp/box.
Old Dec 20, 2004 | 07:30 PM
jsbtn's Avatar
Thanks for the advice!
Old Dec 21, 2004 | 09:00 AM
jsbtn's Avatar
One follow-up. Discounting the fact that the factory sub isn't the greatest, could I still utilize the factory sub by connecting it directly to an AMP and bypassing the stock equalizer?
Old Mar 31, 2005 | 02:13 PM
Bxscig's Avatar
Hey jsbtn, I just got done doing this and I got it to work. From my understanding we could still use the stock AMP BUT it would be much easier and better to get another AMP to hook it up to the stock sub. I missed my bass so much until I got this done.
Old Apr 1, 2005 | 11:33 AM
slikz's Avatar
1999 Acura 3.2 TL
Shibar, so if I install an aftermarket HU I`d have to tap my LOC to another speaker?? Cause right now I have the LOC tapped into my subs wires, with stock HU.
Old Apr 1, 2005 | 11:37 AM
slikz's Avatar
1999 Acura 3.2 TL
NVM disregard previous post. I forgot aftermarket HU`s have the RCA outputs.
Old Apr 1, 2005 | 07:43 PM
dep24's Avatar
7th Gear
Try the vendetta 4.5. This might allow you to keep the factory sub with an aftermarket HU.
Soul_Deamon
Nov 13, 2018 04:44 PM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
akbears15
15
Nov 5, 2015 07:06 AM
scionxb3003
Oct 2, 2015 05:50 PM
tmux
Sep 21, 2015 05:11 PM
