CL: Adding Tweeters
Old Mar 18, 2010 | 01:46 PM
Frank109's Avatar
Adding Tweeters
2001 CL-S
hey guys, i just purchased these for my car...
http://www.amazon.com/gp/product/B00...ef=oss_product
and i believe they come with tweeters and crossovers which im new to. i took off the tweeter cover and there's no wires. i changed the speakers before which was easy because i just stripped the wires that was in my stock speakers and put them on the new speakers. but how the hell do i connect the tweeters/crossovers?
thanks for any help
Old Mar 18, 2010 | 05:05 PM
dykyy's Avatar
Well, first we need to know if you are going to amp them. IMO, buying Type R speakers and not amping them is a huge waste. For tweets, grab small gauge speaker wire and connect it to the crossover, same procedure for the woofers. When everything is connected to the crossover you should run the third set of wires (Power) to the power supply which is your amp. The crossover distributes power and freq to the speakers.
Old Mar 20, 2010 | 02:24 PM
Frank109's Avatar
yes i will amp them but i didnt get one yet. any recommendations?
thanks
Old Mar 20, 2010 | 04:51 PM
dykyy's Avatar
Go to Best Buy and find a 4-channel amp preferably Alpine, and go with that. Ull have 2 channels left for playing around. Either put in 1 sub and bridge them or get 2 more speakers, and ur set.
Old Mar 20, 2010 | 06:16 PM
on1wheel01's Avatar
BEst buy?>?? Why u over pay. For a cheap decent amp check into hifonics they sell them on ebay and are good for the money
Old Mar 20, 2010 | 06:58 PM
phipark's Avatar
Not Asian
Your tweeters should be able accept spade terminals or you can solder them directly (which is what I would recommend). Your crossovers should be able to accept raw wire with a screw to tighten them, as is the same on most amps. I also recommend placing the crossovers somewhere else besides the doors.
Old Mar 20, 2010 | 09:14 PM
Frank109's Avatar
how bout this?
http://www.amazon.com/s/ref=nb_sb_ss...fix=pioneer+gm
Old Mar 20, 2010 | 10:06 PM
on1wheel01's Avatar
this for the cheap I've used their mono block amps before and was pleased for the money http://www.sonicelectronix.com/item_...+TXi+6408.html
Old Mar 20, 2010 | 10:58 PM
dykyy's Avatar
Dude, i usually just go to BB or FutureShop just to see whats out there (Out of the popular brand names) and then i go into further research. Thats what i meant. W.e everyone does it their own way i guess, for me, I like to touch and feel the product.
Old Mar 21, 2010 | 08:38 AM
on1wheel01's Avatar
True you can do that if your into main stream brands and such. Whatever works for ppl. I wouldn't be caught dead with the stuff sold in stores but hey that's just me.
Old Mar 21, 2010 | 08:05 PM
Frank109's Avatar
does anyone know if the pioneer gm-6400F is any good?
Old Sep 3, 2010 | 02:34 PM
Frank109's Avatar
Ok so i havent installed my speakers yet because i have been replacing my tranny over a long period of time. I am about to set up my Type R speakers. my friend is going to give me his amp(did not ask what brand but know its 4 chan). Planning to amp 4 speakers(alpine type-r in front type-s in rear). I have been looking at alot of videos and FAQ but dont want to mess up! what would be the best wire set to buy? and does my 2001 CL-S have a stock amp that i need to take out? also i bought my car and the deck was replaced with a clarion DB185mp. Is that deck not strong enough? if so, i plan to replace it with one of these ipod friendly decks... http://www.amazon.com/Pioneer-DEH-22...3542443&sr=8-1
Thanks for all help/ opinions
Old Sep 3, 2010 | 04:30 PM
Frank109's Avatar
also would i need to buy this...
http://www.amazon.com/StreetWires-St...3548199&sr=8-2
and this...
http://www.amazon.com/Meter-Noise-Au...lp_edpp_img_in
or are there amp kits that come with signal cables?
Old Sep 3, 2010 | 04:53 PM
fourthmeal's Avatar
Knukonceptz or Darvex for inexpensive wire kits. Monoprice for speaker wire, or rca wire if you need.
If you are jumping in a pool and don't know how to swim, www.bcae1.com for the basics of car audio so you don't blow something up or cause a fire.
There are many good amps, any amp that is free is better than what you have, but if you find out what it is I can be more of service. A decent 4ch amp runs about $100-150 on the net, $200 or so out there in retail-land.
Old Sep 3, 2010 | 07:03 PM
on1wheel01's Avatar
yea knu wire is good for the cheap. I have a run of it in 1/0 in my car knu kmlx. Prolly gonna pull it out and sell since i no longer have a system
Old Sep 3, 2010 | 07:24 PM
Frank109's Avatar
would a 4 gauge amp kit be good or prefer 0? i couldn't reach my friend today about the specs on the amp. thanks for the info fourth
Old Sep 4, 2010 | 06:21 AM
fourthmeal's Avatar
www.bcae1.com contains a full power wire gauge measuring tool to help understand what gauge you need. 1/0 is for BIG amps and lots of them, 4 gauge fits either multi-amp setups or one big sub amp, and 8 gauge is minimum in my book.
Let's see what that amp is first. BTW if you plan on upgrading to multiple amps (sub, front/rear) then run 4 gauge. At the very least, you could later run another run of 4 gauge and run two amps, and at the most a 4 gauge setup can run two amps of modest power.
Old Sep 15, 2010 | 11:12 PM
Frank109's Avatar
Head Unit Smoking
ok so.....
i just got my car back today from a tranny swap. once i started the car, the unit said it was in protected mode for i don't know what reason. so i figure the rear speakers was making this happen(because it said that when i first added the rears but the error went away). pulled off the wires to the rears and turned on the car. Head unit worked but only the front right speaker was playing. after 10 seconds smoke came out of the head unit and i quickly shut off the car. Before i gave the car to my mech for the tranny swap, i added those 4 speakers over a year ago. why did it just malfunction?
4drviper
Apr 23, 2025 07:13 PM
RLX-Sport Hybrid
3G RLX (2013+)
27
Dec 7, 2018 12:11 PM
datadr
Mar 23, 2016 01:39 PM
merc009
Sep 29, 2015 03:06 PM
Froid
Sep 27, 2015 06:16 PM
