CL: 01 cls aftermarket amp
Old 02-10-2018, 03:17 PM
6th Gear
Ralph93's Avatar
I have a 10" Power bass sub and a JL audio amp but I cannot get the amp to get power on. It work in store before I bought it and everything is hooked up right but no power. I do have the type S model w/ Bose and Navi. is there a wiring harness in the back seat that's hidden like on the 99-03 TL
Old 02-11-2018, 08:37 AM
Bchester6's Avatar
Where did you get your remote turn on (wire) source? You can run a jumper wire from power terminal to remote wire terminal to see if it's the amp or your power source.
Old 02-11-2018, 02:31 PM
6th Gear
Ralph93's Avatar
I put the remote(blue) wire behind the DDIN radio to my amp. Other than that the battery (red) wire is hot and the ground(brown) is on the bare metal in the trunk. Are you in the 757 area I'll meet anywhere idk how to do it the other way
Old 02-12-2018, 08:57 AM
Bchester6's Avatar
Aftermarket head unit or OEM? Do you have a multimeter to get some readings? I'm in San Diego.
Old 02-12-2018, 10:36 AM
6th Gear
Ralph93's Avatar
No It isn't factory I took that out when I bought the car😂 I have a fb my name up there is Ralph banks. We can video call, and Ill show you what I have.
Old 02-13-2018, 08:46 AM
Bchester6's Avatar
Can you provide the HU model? Some you have to turn on the subwoofer channel.
Old 02-13-2018, 09:40 PM
6th Gear
Ralph93's Avatar
Ok will do when I get back 2 VA, I'm in NJ
Old 02-15-2018, 11:00 AM
6th Gear
Ralph93's Avatar
Its a HD 6.2" XD vision XOD1752BT
Old 02-16-2018, 07:54 AM
Bchester6's Avatar
I have no experience with that brand. Go into the audio settings and see if there is a toggle for your subwoofer (on/off).
07-01-2016 10:15 AM
ErikDaGenErik
04-24-2006 02:26 PM
NSX-Tuner
11-25-2003 08:49 AM
23wt
02-04-2002 09:28 PM
Quick Reply: CL: 01 cls aftermarket amp
