01 cls aftermarket amp
I have a 10" Power bass sub and a JL audio amp but I cannot get the amp to get power on. It work in store before I bought it and everything is hooked up right but no power. I do have the type S model w/ Bose and Navi. is there a wiring harness in the back seat that's hidden like on the 99-03 TL
Where did you get your remote turn on (wire) source? You can run a jumper wire from power terminal to remote wire terminal to see if it's the amp or your power source.
I put the remote(blue) wire behind the DDIN radio to my amp. Other than that the battery (red) wire is hot and the ground(brown) is on the bare metal in the trunk. Are you in the 757 area I'll meet anywhere idk how to do it the other way
Aftermarket head unit or OEM? Do you have a multimeter to get some readings? I'm in San Diego.
No It isn't factory I took that out when I bought the car😂 I have a fb my name up there is Ralph banks. We can video call, and Ill show you what I have.
Can you provide the HU model? Some you have to turn on the subwoofer channel.
Ok will do when I get back 2 VA, I'm in NJ
Its a HD 6.2" XD vision XOD1752BT
I have no experience with that brand. Go into the audio settings and see if there is a toggle for your subwoofer (on/off).
