** Need help!! Rockford Fosgate 1000BD Amplifier 1000 Watt Mono Amp**
Got a Job!
Anybody who's anybody in car audio, do you know if this is a good amp?? I'm thinking of getting 1 10" or 1 12" JL W3v2, W6v2, or an Infinity Kappa PERFECT. Theres one on ebay for $220 and I'm thinking of buying it. Please let me know!!! The auction ends in 10 min!!!!
If you can give me ANY other input on GOOD amps, name them all, please! I know JBL, JL, Phoenix Gold, and PPI are good, right? Are there any others? How about MA, or Kicker, etc??
What about the
Rockford Fosgate 700S Punch Car Amplifier 2 Channel Amp??
or
Rockford Fosgate 801S Punch Amplifier 2400 Watt 2CH Amp??
What about the
or
Got a Job!
I really dont know anything about amps or whatever. If you have one sub, can you only have a one channel amp? What if you had a 4 channel amp, or a 2 channel? And how do the whole ohms thing work?
And with our car (CL-S), if I wanted to upgrade the speakers and get a new amp, would I need a 4 channel amp? What about the tweeters, what powers them? I'm so clueless when it comes to this stuff.
Ahhhhh, auction ends in 2 min 30 sec!@
Got a Job!
Ahhhhhh fuck, you guys didnt pull through :'(
Anyways, so back to my questions, I really need help with this. Basically as of right now I'm going to get an amp and a sub, that's it. I'll stick with the stock HU and the stock speakers for now. Now how do the channels and the ohms thing work? I'm looking to spend about no more than 5-600. On ebay, you can get one of the above amps for like 150-300. The infinty perfect is like $130. The W6v2 on the other hand is a little bit more expensive. I need help choosing what to get. If anybody has any good advice on good shit to buy, please let me know!
Fuct in the hed!
The JL W6V2s are awesome subs. I'd say get a 10 or 12W6v2 and a good clean 500 watts....like a JL 500/1 and you'll have more than enough bass! I have a 10W7 and a 500/1 and it sounds like 2 12"s.....easy.
Got a Job!
thats too much money...a 10" w6v2 goes for $239 on ebay. A w3v2 goes for $130 though? Is there THAT much difference from the two? And to get a 500/1 JL amp, its like $389 brand new, or $340 used.
Is a 10" w6v2 worth the extra $110 over a 10" w3v2?
What about an Alpine Type-R? Or the NEW Alpine Type-S?
or what about the Polk MOMO sub in the custom enclosure?
another this is that like, I can get 2 10" infinity perfects for $220. Or I can get 2 10" Alpine Type-S for $132
http://cgi.ebay.com/ws/eBayISAPI.dll...095227117&rd=1
Fuct in the hed!
I'd say its worth the money.....go to JL's website....the 10W6 has 60% more output than the 10W3.......so technically its like almost 2 10"s.....although 2 10W3s off of a 500/1 would be nice too!
Poppin them thangs
Dem1K, get 1 10" W6V2, if you like to have trunk space. Also, look into the Kicker L7 solobaric sub, its much cheaper than the JL, if you match that with the Kicker 600.1 amp you have in your other post, it would be a perfect fit...both are sick subs....
specs:
KICKER SOLO-BARIC S10L7 (about $120+ on ebay)
10" Square subwoofer
1,200 Watts total output (600 per voice coil)
600 Watts RMS
Frequency responce: 24-100Hz
Dual4-ohm voice coils (2 of them @ 600 watts each)
Sensitivity 85.4dB
Sealed Box Dims: 0.66 - 1.00 cu.ft.
Ported Box Dims: 1.25 - 2.25 cu.ft.
Cast Aluminum Basket
Double-Stitched Santoprene Rubber Surround
Perimeter Venting Cooling System
JL Audio 10w6v2 (about $240+)
Nominal Diameter: 10 inches (250 mm)
Continuous Power Handling: 400 Watts
Voice Coil: 2.75" diameter, 4-layer, Kapton former
Available Configurations: Dual 4 ohm only
Xmax (one-way, linear): 0.60" (15.2 mm)
Sealed Enclosure Range: 0.50-1.00 cu.ft. (14.0-28.0 liters)
Ported Enclosure Range: 0.75-1.25 cu.ft. (21.2-35.5 liters)
VRC™ Technology: YES
W-Cone™ Technology: YES
Elevated Frame Technology: YES
Floating Cone Attach Technology: YES
NeckVent™ Technology: YES
1-year Warrenty
specs:
600 Watts RMS
Sensitivity 85.4dB
1-year Warrenty
Got a Job!
I've heard about the L7's, but I dont like the look of em, plus I trust JL. Ive used them before, so I'm goin with them.
Anyways, chek out this thread I made...
http://www.acura-cl.com/forums/showt...hreadid=139979
Tell me which amp would be THE best to get. Remmeber, I want to stay under $270. I'm leaning towards the Kicker and the Alpine, however I'm unsure which? Someone told me if I could, get a used JL 500/1, however I'd rather have a new? I dont know if having used audio equipment is bad? Hit me up, thanks!
`John
`John
InFaMouSLink
10-30-2015 09:43 AM
4drviper
09-23-2015 09:00 PM
