2011 acura tsx footwell lights
Old Feb 24, 2014 | 01:11 PM
ron4477's Avatar
3rd Gear
Hi,
I am new to this forum. I've recently purchased a 2011 Acura TSX w/ Tech package. I have noticed that the footwell lights only turn on when doors are open. I was under the impression they keep it on during night time driving.
Please advise
Old Feb 24, 2014 | 01:34 PM
iCrap's Avatar
TSX AMG Type //M i-VVT
I have a 2010... the footwell lights are always on as long as your headlights are on. Sounds like something is wrong with yours. Unless you are talking about the lights on the doors?
Old Feb 24, 2014 | 01:37 PM
robpp's Avatar
Graphite Ghost
mine go OFF on my 12.
I THINK only stayed on for the 9-10.....but not sure.
Old Feb 24, 2014 | 01:45 PM
ron4477's Avatar
3rd Gear
I am referring to footwell lights, I have red somewhere that in 2011 Acura has changed that.
Anybody can confirm? Otherwise i can get it fixed under the factory warranty if its specific to my car.
Old Feb 24, 2014 | 02:22 PM
MC MiYoung3269's Avatar
Mine go off as well. 2012 V6 Tech
Old Feb 24, 2014 | 04:01 PM
robpp's Avatar
Graphite Ghost
I can read.
LIKE I SAID on my 12 they DO NOT STAY ON.
my bud has an 11 sedan and HIS DO NOT STAY ON.
so IMO there is nothing wrong with your TSX OP.
And to be clear we are talking about FOOTWELL LIGHTS/
Old Feb 25, 2014 | 09:39 PM
CapNcook's Avatar
It's something Acura changed on the 2nd gen refresh. The footwell lighting on the 11-14 do not stay on after the door closes.
Old Apr 5, 2014 | 08:46 PM
tsx type pm's Avatar
My '09 does not have footwells.... hmmm
Old Apr 7, 2014 | 09:34 PM
808CU2's Avatar
What do you mean your 09 doesn't have footwells..??
Old Apr 7, 2014 | 10:30 PM
nexus809's Avatar
^most likely he hasn't discovered them yet, the 09-10 have a black plastic that blocks the light I think 11-up Acura put a clear plastic over the footwell lights. I didn't know mine had em til I did the footwell light mod
Old Apr 8, 2014 | 10:14 AM
soupi's Avatar
i have a 2010 tsx dont notice a footwell light, can someone send me a picture and if it is blocked by a black cover how do i check?
thanks
Old Apr 8, 2014 | 10:41 AM
iCrap's Avatar
In the 2010 there is a diffuser which blocks most of the light.
Just look under your dash and you will see it.
I took mine out.
Old Apr 8, 2014 | 10:54 AM
soupi's Avatar
thanks icrap, another new thing i learned about my car.
Well check it out later today.
Old Apr 9, 2014 | 01:21 PM
soupi's Avatar
i noticed the footwell light had to dial the brightness up. but the light is very vague.. wonder what the point is since you can barely see it...
how would you take out the diffuser?
Old Apr 9, 2014 | 02:42 PM
iCrap's Avatar
just pop out the panel and take out the diffuser, i drilled a hole in mine to let the light pass through. It's pretty bright after that.
Old Jun 24, 2014 | 08:21 PM
cu2-vtec's Avatar
5th Gear
2009-2010 Acura TSX footwell lights stay on when low beams are on. A black lens is used to cut the amount of light making it almost invisible.
2011-2013 Acura TSX footwell lights ONLY WORK when you open the door. They use a clear lens to omit light when the doors are open. Dealer said Acura thought that the light was too strong to stay on while driving at night bc the light was apparently too strong.
I'm going to remove the lens on my 2009 to see how strong it rlly is and put up pictures of the results
Old Jun 25, 2014 | 07:36 AM
soupi's Avatar
thanks vtec, cant wait to see it!
Old Jun 25, 2014 | 08:59 AM
number17's Avatar
Interesting ... I'll go back and check and maybe remove the diffuser on my 09 TSX footwell light then. I have noticed footwell light in mine, but they are indeed dim.
Just to clarify, TSX only has footwell light in the front, not in the back right?
Old Jun 25, 2014 | 09:57 PM
iCrap's Avatar
There is a pic posted somewhere here of the diffuser taken off.
I have them off on my '10. It's much better, you can see the blue color and it's not overpowering at night.
And yeah, it's only in the front.
oh btw, you can't just take off the difuser since it's also the clip that holds the light in place, you have to drill a hole in it.
Old Jun 27, 2014 | 08:12 AM
soupi's Avatar
I drilled a hole in my diffuser, the light output is blue... I think the reason they put the black diffuser is because it causes the footwell light to be whitish which matches the DASH lights, now it is just a blue led on the floor...
which is different since it is the only blue light source, but I dont mind it....
I wonder if there is away to change the small led to a white led instead.. hmmm
Old Jun 29, 2014 | 04:41 PM
iCrap's Avatar
Yeah just unsolder and put a white one.
Old Feb 17, 2015 | 10:53 PM
aczace87's Avatar
can anyone show pics on drilling where? or upgrading those led light bulbs.
Old Feb 23, 2015 | 10:16 PM
dave_88's Avatar
Dude
i drilled a hole in my 09's light; it's too bright and i regret it. does anyone want to trade??
Old Feb 24, 2015 | 01:49 PM
iCrap's Avatar
you know you can dim them with the knob on your cluster?
Old Feb 27, 2015 | 11:19 PM
aczace87's Avatar
For the people with the Acura 09-10 here is a link to get your footwell LEDs to be seen. http://youtu.be/Ip2fQ36vGds
Also I have the Acura tsx 10 and they do stay on with the headlights.
Old Mar 1, 2015 | 03:32 PM
evo9's Avatar
Mine got both front rear & center console. Center & rear stays on, front goes out when doors are closed.
Old Mar 4, 2015 | 12:23 PM
dave_88's Avatar
Dude
then that would dim everything else too. i already have my interior lights pretty dim.
Old Mar 12, 2015 | 08:39 PM
vpcarson's Avatar
I have a 10 TSX and my footwell lights stay on as long as the lights are on. I just removed the black plastic cover and taped (I know getto) the light to the hole so it wont move. The black plastic cover holds the light in place. I didn't even know I had footwell light untill a few months after having the car because of how dim it is with the cover. looks better now but I think I might change it out for white ones to match the rest of the lights.
mada51589
Jan 9, 2025 04:40 PM
Soul_Deamon
Nov 13, 2018 04:44 PM
Legend2TL
Motorsports News
Jan 31, 2016 09:27 AM
Heyzuez20
Oct 14, 2015 07:18 AM
Mr.Tea
1/2G MDX (2001-2013)
26
Oct 9, 2015 04:27 PM
