Dropped/lowered/slammed 2G TSX - Pictures, Details, Reviews
#201
Attachment 103368
Attachment 103370
1. Megan Street Series Coilovers - No idea on exact ride height, haven't measured.
2. Don't know the exact camber specs, but it isn't too much.
3. All four corners rolled.
4. VIP Modular VRC13 19x9.5 +15 (5mm spacers all around) painted a custom copper color.
5. (2) General G-MAX 225/35/19 Rear - (2) Achilles ATR Sport 225/35/19 Front
6. Rides surprisingly well considering the wheel/tire setup. No rubbing at all, the coilovers are great! No bottoming out whatsoever, just a intermittent clunking sound in the front when going over certain bumps, not all. Still trying to diagnose the issue, but other than that - no complaints!
Attachment 103370
#204
Specs:
VMR V701 18"x9.5
+45 Offset
235/40R18 Michelin Pilot Sport A/S3
Eibach Pro-kit
Koni's Yellow's up front, stock struts rear (blew front right strut after lowering, same corner hit a pothole so probably was on its way out)
Now to the pics:
VMR V701 18"x9.5
+45 Offset
Eibach Pro-kit
Now to the pics:
#205
Not feeling the side skirt
Car looks good
What part of Toronto is that, the ghettoest part?
Car looks good
#206
Lol not exactly, took it outside the best alignment shop in Toronto. You can see it in the background. But it's close to downtown where the houses are close to a million so not close to the ghetto by any means, although the industrial area usually look it.
#207
Been to Toronto many times
Gorgeous
Missed the ghetto
Gorgeous
Missed the ghetto
mkalinich (06-07-2015)
The following 2 users liked this post by chuonthis:
ExcelerateRep (03-24-2017),
justnspace (06-18-2015)
chuonthis (08-13-2015)
#215
#216
#217
#218
Megan EZ street
unknown drop, will be lower eventually
Weds Kranze Bazreia 19x10 +5 front, 19x11 +12 rear
225/35/19 and 245/35/19
ingalls front and rear adjustable ball joints max negative camber
front fenders: cut, rolled and pulled 13mm
rear fenders: roll, and pulled 5mm
Megan EZ street
Unknown drop:
side jack points: F - 2 3/8 from the ground, R - 2 7/8
Tru Hart front UCA: -5 camber
Ingalls ball joints (rotated 180 degrees) -9.3 camber
#221
Nice Cu2 everyone!!! I have a crystal black pearl tsx and was looking to order rims in the next 2 weeks or so. Im not lowered as yet and i was wondering if i can run 19x9.5 ET 35? The wheel i was looking to get is Niche Milan M134. Milan - M134 - MHT Wheels Inc.
Thanks in advance
Thanks in advance
#228
#229
New to Group - Need Help - Lowering Springs 2009 Acura TSX
Hey All
Finally purchased my dream TSX, Bought some 18" 3SDM wheels but im gonna need to lower it, what brand and details would you all recommend
#230
Megan Racing EZ street coilovers
Drop not really sure: Front fenders sit 23.25 in off the ground. Rears are 24 in off ground
Fronts:Megan Racing Upper camber armin the front. adj to 4 degrees of camber
Rears: Its all natural camber at 5 degrees
Fenders are rolled in the rear but the fronts haven't been rolled
Tires: all 4 Federal SS595 225/35/19
Wheels Rotiform TMBs 19x10 +25 offset
Rears are at a +20 bc of my 5mm spacer
#232
It wasn't hard at all with the right stuff.. I only did the rears I didn't touch the fronts at all.. Just whatever you do you need a heat gun to avoid paint cracking
#233
Lowered on Tein Street Advance with Avant Garde m540 19x9.5 all around wrapped with 225/35/19. 10mm Spacers in rear with all fenders rolled.
I think I've lowered it a little more in the front and back since this picture was taken. Want to be lower but cannot clear my driveway without the tire hitting the fender when i turn up
2012wagon (12-25-2015)
#235
#237
