Trunk won't open using Key Fob, Door Trunk Release or Trunk Release Button
Out of the blue my trunk will not open. I used both of my key fob, inside door trunk release button, and also the outside trunk release button. Nothing works. I even check on the glove box and the switch is On. But for some reason when I am was sitting in my car and press the key fob or the button by the door, I can hear a soft sound of a "click" by the driver side footwell. Not sure what that might be. Only way I can open my trunk right now is the rear deck using the key to open it manually.
I'm thinking to see if I can try to disconnect the car battery and reconnect and see if that will reset everything.
Like to see if there any other insight out there that have this issue.
Thinking I saw here or on Facebook not too long ago someone with similar issue, their trunk wouldn't open with trunk button, the door button/remote worked though. Disconnecting battery fixed it for them.
