Speed Limit Icon gone
2021 TLX Aspec
Has anyone had this happen:
the speed limit icon, first, was a blank rectangle with a diagonal line through then - it disappeared altogether (went back and forth between the two on my seven-minute commute).
Does frost have anything to do with that? I did leave my car outside overnight due to concrete work on driveway, and there was some frost but nothing requiring scraping.
I looked over the owner’s manual but found nothing.
thanks!
thanks!
This post/thread has been moved to the model specific forum for better response.
That is normal. The traffic sign recognition relies on reading physical signs as you drive about. It is not coming from some predetermined database. If sign speed limits change over time, the car should pick it up as it passes.
I've had it read 100 mph once so it's not perfect!
xizor
1G TSX Racing & Competition
14
10-04-2004 06:51 AM
