Type S Surround View Mod
Old Jun 24, 2021 | 07:09 PM
Ghostof TypeS Past's Avatar
The only thing I wish the Type S had more than anything else, was the surround view camera for the front!
Will be looking into this more upon delivery of mine and piercing together the parts for the upgrade (Could be just a dream!). Let’s find out if this can be done! (Could be just a dream!)
For now:
Here’s the front grille link.
https://estore.honda.com/acura/parts/view-acura-parts-catalog-detail.asp?m=2021-tlx-4-advsh-awd-xat&sn=&b=B++45&dl=#
Front Camera P/N: 36560-TGV-A03
Surround Molding P/N: 71122-TGV-A00
Camera Cap P/N: 71126-TGV-A00
Camera Assy R Side P/N:
36660-TGV-A03
Camera Assy L Side P/N: 36670-TGV-A03
Old Jun 24, 2021 | 08:31 PM
you would probably need the engine harness as well.
Old Jun 24, 2021 | 09:13 PM
No doubt. Haven’t been able to find an image of the harness assy.
May also need to do some software uploading to have the system recognize the system unless it’s plug and play.
Old Jun 24, 2021 | 09:56 PM
nah, if it's the same ECU, the engine harness will take care of it.
if it's not the same ECU, then add that to the list.
- Front Grille
- Front Camera P/N: 36560-TGV-A03
- Surround Molding P/N: 71122-TGV-A00
- Camera Cap P/N: 71126-TGV-A00
- Camera Assy R Side P/N:
36660-TGV-A03
- Camera Assy L Side P/N: 36670-TGV-A03
- Engine Harness
- Possibly ECU
so in other words, mighty expensive.
just thought about the ecu..
if you change the ECU, then the type-s WONT operate.
so, the idea is probably dead in the water.
perhaps, the Type-s ECU has the written surround view code on it...? probably not, until someone gets their hands on it and looks at the code.
Old Jun 24, 2021 | 11:28 PM
Edward'TLS's Avatar
6G TLX-S
Even if the Type-S ECU has the surround view code, you still need to find a way to enable it. You can't just add all the cameras and expect them to work like "plug and play".
Old Jun 25, 2021 | 07:35 AM
ELIN's Avatar
OP, you might be better off with a different car if it's that important to you.
Old Jun 25, 2021 | 09:08 AM
We won’t know officially. The surround module may send communication to the infotainment.
Also need the a new wiper stalk with the camera button.
Old Jun 25, 2021 | 03:49 PM
mike03a3's Avatar
Air Vice Marshal
The Canadian Type-S has the surround view.
Old Jun 25, 2021 | 05:00 PM
^if that's the case, here's hoping acura saved monies by using the same engine harness...meaning, there will be extra pigtails for one to connect the cameras into
Old Jun 25, 2021 | 05:47 PM
Edward'TLS's Avatar
6G TLX-S
Easy then. Buy the Type-S in Canada and have it imported to the US.
Old Jun 25, 2021 | 11:20 PM
Right but the CA Type S. And get Y spoke wheels!!
Old Jun 25, 2021 | 11:21 PM
*buy
pcmcia
3G RDX (2019+)
Aug 4, 2018 07:02 AM
donq
17
Sep 5, 2017 10:49 AM
turbocivic94
May 31, 2010 01:20 PM
synth19
Cameras & Photography
23
May 9, 2009 04:57 PM
Tintin
17
Mar 31, 2007 10:53 PM
