Spare tire or repair kit ?
6G TLX-S
There seems to have no factory information as of which TLX package trim(s) come with a spare tire and which come only with a repair kit. Can TLX owners please confirm ?
I don't think any come with the spare tire. I was told it is something that can be purchased separately for around 150. They should all come with the repair kit unless built otherwise from the factory/dealer choice.
Edward'TLS (03-23-2021)
None of the 2.0 TLX come with a spare tire.
Edward'TLS (03-31-2021)
I'm sure it's to optimize fuel econ. Once an owner puts a spare in, the car no longer needs to conform to the EPA rated fuel economy since it's no longer the stock specification.
What I want to know, is what do you do if you get a blowout, at night, or on the weekend? DUH!
Nope, that's just what auto manufacturers tell us......it's 100% about costs. 30 years ago cars had full size spares, then donuts, and now a can of fix-a-flat or an inflator. If a tire and donut cost the auto manufacturer $150 each and they sell a million cars and the inflator costs them $50, they're saving $100,000,000 from that alone.
ELIN (04-01-2021)
6G TLX-S
I asked that exact question because I came from a '18 MDX that had a spare. I will call roadside assistance every time since it's built into the cost of ownership/lease.
Edward'TLS (04-01-2021)
Where do they tow you at night or on weekends? I have tire & wheel insurance, but it's useless off hours
A spare tire is the best choice; unfortunately, the TLX doesn't offer one
Probably should buy a spare if you're using it as a family vehicle.
6G TLX-S
The dealer told me that they will attempt to make the repair using just the plug kit first. If it can't be repaired on the spot, they will tow it.
Still, nothing beats the peace of mind of having a physical spare tire at the back of the trunk.
6G TLX-S
If not as above, then the repair is not permanent, and will require a separate trip to the tire shop for a permanent repair.
Worse still if the roadside assistance guy uses those fix-a-flat-sealant kit to repair the flat tire, because it is a temp fix, the sealant is very messy to clean up for tire shop permanent repair, and the sealant might ruin the TPMS sensor if not handled properly.
Has anyone tried putting a space-saver tire and wheel under the trunk floor and over the battery? I don't get my new TLX for a few days so I can't check the space. But it seems like there is a big styrofoam thingamajig that holds the inflator kit. If this was removed, would there be enough room for a space-saver wheel? I'll bet junk yards have lots of those and scissor jacks kicking around.
Do you know if the roadside assistance repair job gonna be the same as those performed from tire shops, which involve unmounting the leaky tire, gluing a repair patch on the inside of the tire and also plugging up the hole if necessary ?
If the tire has a large cut or is otherwise severely damaged, you will need to have the
vehicle towed. If the tire only has a small puncture, from a nail for instance, you can
use the temporary tire repair kit so that you can drive to the nearest service station
for a more permanent repair.
The kit should not be used in the following situations.
Instead, contact a dealer or roadside assistance to
have the vehicle towed.
• The tire sealant has expired.
• More than one tire is punctured.
• The puncture or cut is larger than 3/16 inch (4.8 mm).
• The tire side wall is damaged or the puncture is
outside the contact area.
• Damage has been caused by driving with the tire
extremely under inflated.
• The tire bead is no longer seated.
• The rim is damaged.
Do not remove a nail or screw that punctured the
tire. If you remove it from the tire, you may not be
able to repair the puncture using the kit.
NOTICE
Do not use a puncture-repairing agent other than the
one provided in the kit that came with your vehicle. If
a different agent is used, you may permanently
damage the tire pressure sensor.
Buyer beware!
Edward'TLS (04-02-2021)
6G TLX-S
No spare tire. So cannot venture too far out from the cities. Sigh !!!
echodigital (05-20-2021)
6G TLX-S
How do you store/secure the jack and the wrench ?
In the Modern Spare bag (picture 4). i called the dealership to order a spare. They quoted me a price of $800 (tire, rim and installation), but stated it was on back order. There was NO WAY I was going to pay that much for a spare. Ordered thru Modern Spare and the order arrived 3 days later.
Edward'TLS (10-06-2022)
