Patrick, owner of 2017 TL, SH-AWD, with technology
Old Nov 11, 2019 | 09:21 AM
Jack1143's Avatar
Hello, I changed coils and plugs and found
oil on 2 plugs, sounds like valves tapping, any diagnostic thoughts? Thank you
Old Nov 11, 2019 | 04:08 PM
Ron A's Avatar
Administrator
Welcome to the forums.
Since this is a topic/technical issue which will require replies and discussion, this thread has been moved from the New Member Introductions forum to the model specific forum.
Old Nov 11, 2019 | 06:21 PM
csmeance's Avatar
Direct Injection on the TLX is pretty loud and can be confused for valve tap! With that said, you can perform a valve adjustment if needed. The oil on the 2 plugs, was it soaking or light covering? Are you low on engine oil at all? The PCV if faulty can cause abnormally high crankcase pressure causing all sorts of issues/noise so def. look at that.
Old Nov 12, 2019 | 07:03 AM
someguy11's Avatar
Some Guy Who Loves Cars
I swear my TLX V6 had a lifter tick from the day I bought it, but everyone on this forum and my dealer all said it was normal. The tapping is definitely more pronounced on the TLX V6 than any other car I've ever heard idling. I would call it abnormal.
As far as the oil on the plugs - which cylinders? Honda lost a VCM class action lawsuit for the VCM2 system rings leaking oil, fouling plugs and causing misfires. on deactivated cylinders. I think 5 and 6. The TLX V6 has VCM3, which supposedly avoids this problem, but I'm skeptical. Did you ever throw a misfire code?
Harrisroad1
15
Aug 17, 2018 01:16 PM
2Blueyam
Nov 15, 2017 06:24 AM
fissile
Oct 18, 2017 12:32 PM
MsAdry
Jul 17, 2017 02:02 AM
