passenger door unlock???
Hi guys, just noticed this yesterday, not sure if this is the way it design or something is wrong. After engine is started, with only driver door is unlock, I cannot open the passenger door from the outside by either grabbing the door handle or remote control. The only way to unlock is walk over to the driver side and unlock from the main control switch. Is this normal?
Thanks for the replies guys, but it not childproof lock since this is for front door or the door lock setting (at least I dont think). It only happened if the engine is already started. I can unlock the front passenger door either by grabbing the door handle, press the button on the door or by the remote control if the engine is OFF. I just want to double check with you guys to see if this is normal or not before bringing in the car. Kinda lazy to go with all the traffic and all lol
If you have a key,the passenger door will open if you grab the outside handle--because you have the key on you. If other people try to open it, it remains locked unless you press the unlock button on the inside driver door. You can set the car, as noted above, to unlock just the driver door or all 4 when the outside handle is grabbed. If you opened the driver door and got in, even started the car, the other doors are locked unless you change the setting (in the manual). It's a safety feature so someone can't jump in your car after you open your door--but you can change it.
Darn, I need to learn how to read the manual carefully lol. Thank you all for the info. I try to avoid taking it to the dealership, usually come back with another issue. I brought my car in for lkas and ldw check, and now my tranny is acting up more than usual =( With this door lock is normal, it is one less problem I need to worry.
Kinda annoying if I can't even unlock the rest of the door with the remote once the engine is started. Not that I need to do it all the time, but I'm sure every now and then in the future, I have to run back to the driver side and unlock lol.
I think this is what he is talking about. If you have remote started the car when you grab the handle it only opens the drivers door. Probably to prevent someone from jumping in the passenger side while the car is running. If I want to unlock the passenger side I just hit the unlock button on the drivers console. If you use the fob while the car is not remote started it will unlock all the doors if the settings are set that way.
Scottod102
03-08-2016 10:14 AM
Kesler123
2G TSX Problems & Fixes
02-26-2016 12:30 PM
