Key fob sometimes doesn’t work
My 2017 key fob sometimes doesn’t work for a few min to open doors etc, and no lights on the fob. Starts car fine in the car so I don’t think it is the battery. Then then starts working fine. Typically happens lately when I haven’t been driving much. Once it starts working, then ok.
It is just the key fob. The lights on the fob don’t work and it won’t unlock. Then after a few min of trying it starts working and seems no problem. This has happened a few times lately.
I would suspect that the battery in the key fob is low. I had to replace the battery in my fob last Sept. in my 2017 tlx Tech. The car did give me a warning that it was low. Just follow the directions in the manual. Be careful as the buttons can get mis-aligned if it does not go back together right, or have the dealer do it. You could also test with your other key fob to see if that works.
The 2nd keyfob wasn't working either, so that was confusing. I changed the battery on that one, and now 2nd one works.
On the first one, after a bit then it works fine. I reseated battery, as maybe some oxidation etc, so we'll see how that goes, and then I'll change battery if still a problem.
Also, in the past when battery was low it would say so on the car display, so that wasn't adding up either.
Carl
Carl
Walks
Nov 1, 2019 09:41 AM
