First time Acura TLX owner needs help
Old Jul 24, 2020 | 08:27 PM
markoni's Avatar
4th Gear
Hope I am posting this right, new to the forum...
I recently purchased my first Acura, a 2017 TLX with the 3.5 V6. It was purchased through Carvana. Great looking car, brisk acceleration, drives well around town. Now has 47K miles with, per Carvana, new tires that were put on at 45k.
The problem I'm having is highway driving, it's causing me to become really disappointed with this vehicle. In fact I hate driving it on the freeway, because at varying speeds, sometimes 55, 65, or 75, the car vibrates noticeably. It feels like the whole body is lightly shaking, I can feel it and I can see the passenger seat shake. Interestingly the steering wheel doesn't shake, so it doesn't seem like it's a tire issue (tires are relatively new). At 75MPH, my water bottle in the cup holder is rattling against the sides of the holder.
Could this be somehow related to the VCM issue I've read about on this website and others? Or something totally different? I don't know what to do, I feel like trading the car in, mostly out of frustration. But I'd rather keep it if I could find an answer to this problem.
Thank you.
Old Jul 24, 2020 | 10:40 PM
fiatlux's Avatar
Is this the FWD or SH-AWD model? There's been a number of reports of vibration issues with the latter, though I'm not familiar with what the resolution is.
Old Jul 24, 2020 | 11:44 PM
dezymond's Avatar
Sounds like motor mounts maybe. Check those. It could be VCM if you're FWD
Old Jul 25, 2020 | 04:24 AM
Midnight Mystery's Avatar
Null and proud of it
Wasn't there a TSB on the ZF-9 for the 15 V6 models?
Was it fully resolved for 17?
Old Jul 25, 2020 | 05:47 AM
I would put money that it's either these two suggestions.
someone will have to inspect the car for the motor mounts and drive shaft issues.
Old Jul 25, 2020 | 11:10 AM
markoni's Avatar
4th Gear
It's the FWD model, not SH-AWD. Thank you for your reply.
Old Jul 25, 2020 | 11:12 AM
markoni's Avatar
4th Gear
Thanks for replying, I forgot to mention it's the FWD model not AWD. Do you know if there's anything obvious I could check for re: motor mounts, or something only a qualified Acura tech would be able to see?
Old Jul 25, 2020 | 11:45 AM
markoni's Avatar
4th Gear
Thank you for replying. It's FWD--it would only potentially be a drive shaft issue if AWD, is that right?
Old Jul 25, 2020 | 02:01 PM
The easy way to do it is to have someone shifts gears while stopped and rev the engine. If the engine moves around a considerable amount, your mounts are shot. Either that, or look with a flashlight to see if they have cracked anywhere.
You are correct, FWD has no rear driveshaft.
Old Jul 27, 2020 | 06:09 AM
TSXV6Guy's Avatar
I suggest you start with checking the wheel balance, specially since the tires were recently changed, They may have improperly balanced them or used an uncalibrated wheel balancer. Try a reputable tire shop that uses a road force machine.
Old Feb 22, 2021 | 01:53 PM
jonjonwin's Avatar
4th Gear
Have your tires re-balanced at the dealership or good tire shop.
chawdhry
4G TL Problems & Fixes
Apr 18, 2011 02:30 PM
JDM101
1G TSX Problems & Fixes
Apr 26, 2010 10:45 AM
yarsix
Mar 1, 2007 10:47 AM
John*K
Jul 11, 2003 12:32 PM
Black 2003 Styp
Dec 17, 2002 10:08 AM
