drivers side window
drivers side window
anyone's driver side window decide to play games with them when they press the button to roll it up? It goes up most of the way, then right back down halfway. It will do this a couple of times and then decide to go fully up. This happens randomly. Does anyone have a fix for this?
After cleaning the channels like thoiboi said, use some silicon lube (spray) to lubricate them. Then, try resetting the auto up/down function:
- Move the power window all the way down with the power window DOWN switch.
- Pull up and hold the power window UP switch until the window reaches the fully closed position, then continue to hold the switch for at least 1 second.
