drivers side window
Old Sep 2, 2020 | 10:57 PM
Sigwill24's Avatar
Team Anthracite Member
drivers side window
anyone's driver side window decide to play games with them when they press the button to roll it up? It goes up most of the way, then right back down halfway. It will do this a couple of times and then decide to go fully up. This happens randomly. Does anyone have a fix for this?
Old Sep 3, 2020 | 12:17 AM
Check and make sure the channels are clean and clear of debris, if thats clear then you may have to look at the regulator to see if something is being caught
Old Sep 4, 2020 | 05:50 AM
TSXV6Guy's Avatar
After cleaning the channels like thoiboi said, use some silicon lube (spray) to lubricate them. Then, try resetting the auto up/down function:
- Move the power window all the way down with the power window DOWN switch.
- Pull up and hold the power window UP switch until the window reaches the fully closed position, then continue to hold the switch for at least 1 second.
paperboy42190
Sep 25, 2015 10:15 PM
PrissyJayne
Jul 22, 2011 10:05 AM
josiel
Mar 3, 2011 12:18 PM
Tolik
Aug 27, 2009 09:24 AM
