iOS 11 Handsfree link error.
Old Oct 6, 2017 | 11:02 AM
  #41
Speed_Racer's Avatar
6 Forward 1 Back
2018 TLX ASpec with iPhone 7+ and iOS 11.0.2
I didn't have the Bluetooth volume issue, I had the Phonebook issue and fixed it by manually turning off the auto sync and turning it back on. When I did that my Phonebook on the TLX populated with everything from my phone with names and my Call History showed all the names again. The Phonebook stayed intact after restarting the phone and the car a couple of times. Let's hope it stays. I'll report back if not. . .
Old Oct 6, 2017 | 11:06 AM
  #42
akadennis's Avatar
9th Gear
This worked until I made a phone call. They appeared and then disappeared once I hung up. Voice recognition doesn’t work either since it wipes out your address book.
Old Oct 6, 2017 | 11:16 AM
  #43
6 Forward 1 Back
That's weird. I just tried to make 3 different calls and the Phonebook remained each time. I then tried to turn off the car and start it back up. Phonebook is still there. I'll keep a look out if anything changes, but it appears mine is sticking so far.
Old Oct 6, 2017 | 11:19 AM
  #44
akadennis's Avatar
9th Gear
That’s great for you :-) not so much for me :-(. Once I turn the car off or make a call or use voice recognition it all disappears. I pretty much have given up and will probably get an Android for my next phone.
Old Oct 6, 2017 | 05:26 PM
  #45
RDXTLKen's Avatar
My phone book syncs except for my wife’s and a few of my best friends! I probably shouldn’t tell her.
Old Oct 6, 2017 | 05:44 PM
  #46
RDXTLKen's Avatar
I just figured out my error. Contacts that are stored in iCloud or my work exchange server are not synced. They used to.
Old Oct 7, 2017 | 06:29 AM
  #47
Frances15's Avatar
3rd Gear
2015 MDX Advanced Package
i am having all the same problems as many of you are since upgrading to IOS 11. Pandora and phone book import issues are the main ones that I have noticed. I hope we have a fix soon!
Old Oct 7, 2017 | 10:48 AM
  #48
Almas Khan's Avatar
Just wanted to chime in, I have an iPhone 8 (iOS 11.0.2), and tried everything to fix the phonebook issue, resetting network settings, all settings, factory restore without backup. Nothing works, and the Apple technician I talked to over the phone said this is a common issue he'e been seeing. I'm only seeing bluetooth connecting and disconnecting. The Apple technician said this is because software on the phone is crashing when doing some exchange with the car, and it restarts and connects.
Huge headache... this needs a fix. It's not Acura's side, it's Apple's.
Old Oct 7, 2017 | 06:20 PM
  #49
SCADAczar's Avatar
Just wanted to add my 2 cents worth. I'm not entirely convinced this all Apple's fault. I just got a new iPhone 8+ and I'm experiencing the same phonebook import issues as others have reported. When I first paired the phone with my 2015 TLX, the entire phonebook synced up with the car. The next time I started the car, only 3 out of 105 contacts showed up in the phonebook. Also I've seen the bluetooth connection with the car randomly disconnect and then reconnect while driving. However, I also paired my iPhone with a Pioneer AVIC-4200NEX head unit that's in my MR2 and it has worked flawlessly every time. I've driven the MR2 multiple times and each time I've verified that the entire phonebook has synced and I've never seen the bluetooth connection fail once. I don't what the differences are between how these 2 head units handle the bluetooth connection but only my TLX is having issues.
Old Oct 9, 2017 | 05:15 AM
  #50
akadennis's Avatar
9th Gear
This only started once i updated my iphone to ios11. There is another known issue with this update and AT &T at least. I have 3 phones on my account and I normally have to turn off data on one (not on the phone but on the app since the phone belongs to my 17 year old) I have been doing this for the last few years and now when I turn off the data it also turns off the service so no calls can be made or received on the line. Was told by ATT that it was a bug with apples new ios. I too only get 3 contacts. Turning off auto sync and turning it back on gets my contacts and address book back on, but as soon as I get a call, make a call they all disappear. Voice recognition doesnt work either since it wipes out your contacts. Very frustrating to say the least.
Old Oct 9, 2017 | 07:51 AM
  #51
nhester's Avatar
Interestingly... I have iOS 11 installed on an iPhone 7 and CarPlay in my 2018 TLX-Tech seems to be working flawlessly. Maybe I'm missing something?
Old Oct 9, 2017 | 09:26 AM
  #52
CPR's Avatar
CPR
Ios 11.0.2
Once again, my 2015 TLX/SH-AWD/Tech, syncs flawlessly, with my IPhone 64GB SE/TMobile
I'm starting to think that maybe , it depends on the service provider
Checked my 200+ contacts, 3 or 4 times over the weekend; PERFECT!
The BT call reception, & BT Audio, are ideal
Don't know if it's Apple, or the providers, but I'm happy
Old Oct 9, 2017 | 02:05 PM
  #53
t5620's Avatar
iOS 11.1 beta 2 released today has the same problem, of names not showing on recent calls and empty phonebook.
Old Oct 9, 2017 | 02:06 PM
  #54
t5620's Avatar
maybe it is just an iPhone 7 and 8 problem
Old Oct 9, 2017 | 03:53 PM
  #55
ogiewon's Avatar
This is not a CarPlay problem. The problem is when using a Bluetooth connection and using the Acura Hands Free Link Bluetooth phone features with iOS 11.
Old Oct 9, 2017 | 03:58 PM
  #56
t5620's Avatar
exactly it is only via bluetooth, anyways I won't be updating my iPhone 7 to iOS 11, luckily I still got 10.3.3 on my main driver. I contacted apple support and they are clueless, and they're blaming the car stereo of not being compatible with iOS 11 which is bullshit. I'm very sure the bug happens because the way iOS 11 handles bluetooth.
Old Oct 9, 2017 | 04:09 PM
  #57
t5620's Avatar
at first all contacts syncs.
then all contacts disappears and only one contact is left
Old Oct 9, 2017 | 05:32 PM
  #58
Frances15's Avatar
3rd Gear
Originally Posted by jbac
Hi folks,
I work in a Acura we have the phonebook issue on all the iOS 11 we tested. We tried it on 2017-2018 models only, but it's the same thing on both of them. As soon as I ear from the manufaturer I'll let you know what is the fix.
Yes! Please keep us updated!!
Old Oct 9, 2017 | 05:37 PM
  #59
Frances15's Avatar
3rd Gear
I am having all the same issues on my iPhone 6.... 😩
Old Oct 9, 2017 | 06:14 PM
  #60
akadennis's Avatar
9th Gear
Just wanted to mention that I have the 2016 RDX. Still have all the issues described above.
Old Oct 9, 2017 | 06:30 PM
  #61
SCADAczar's Avatar
I did more experimenting today, this time pairing my iPhone 8+ with my wife's 2016 Audi. I found that everything worked perfectly and all the contacts in my phonebook imported correctly and remained synced with the car no matter how many times I shut off and restarted the car. I've now paired my iPhone with 3 different head units and the only car that has bluetooth issues is my 2015 TLX.
Old Oct 9, 2017 | 06:32 PM
  #62
akadennis's Avatar
9th Gear
hmm interesting. not sure what to make of this. either way all my issues started as soon as I updated the IOS. Maybe Acura needs to update their firmware which I don't see happening anytime soon.
Old Oct 9, 2017 | 11:28 PM
  #63
Kevangi's Avatar
2016 TLX advance
Same problem. Once I updated to iOS 11 on my iPhone 7 phone book does not sync. I purchased the iPhone 8 same issue even after the iOS 11 updates.
On my Jeep Renegade and my wife’s Volvo XC60 all contacts sync and stay synced. Then I tried syncing with the Bluetooth on my dad’s Subaru Forster and my brothers Mercedes ML and it works perfect.
Acura is the only vehicle that I know of from speaking to friends who updated to iOS 11 that have a problem. Good thing my TLX is a lease and goes back in a year.
Old Oct 10, 2017 | 06:37 AM
  #64
nhester's Avatar
This is likely correct! I have not yet checked the BlueTooth Hands Free... but, I'm curious: Does the Hands Free system offer any features that are not also provided via CarPlay?
Old Oct 10, 2017 | 10:05 AM
  #65
ogiewon's Avatar
Yes, it is wireless! That's the single biggest advantage that I can think of. Also, please recall that CarPlay is new to the 2018 model year. Most owners do not have CarPlay.
Old Oct 11, 2017 | 08:06 PM
  #66
t5620's Avatar
11.0.3 has just been released can anyone comfirm if the issue still present
Old Oct 12, 2017 | 06:23 AM
  #67
akadennis's Avatar
9th Gear
downloading it now. probably a safe bet this update doesnt fix anything since the release notes make no mention of this issue
Old Oct 12, 2017 | 07:28 AM
  #68
akadennis's Avatar
9th Gear
I can confirm this update did nothing to fix our issue
Old Oct 13, 2017 | 07:24 AM
  #69
t5620's Avatar
thanks for the confirmation, I guess it won't be fixed soon I bet apple is not even aware of the issue
Old Oct 13, 2017 | 08:59 AM
  #70
CPR's Avatar
CPR
Cool Joining the party
IOS 11.0.3/2015 Acura TLX/Tech
Last night, after starting the engine, only SOME of my contacts were synched
Turned the car completely OFF; DELETED my IPhone, & turned OFF Bluetooth
Upon re-installing EVERYTHING, the same problem persists
Weird, because IOS 11.0.2 was fine
Of course, Acura blames Apple, & vice-versa
Suggestions?
Old Oct 13, 2017 | 10:34 AM
  #71
jimblock's Avatar
Unhappy
Well, I have filed a formal BugReport with Apple. (Not saying that they have responded to it yet).
I suggest that others file a BugReport, too. You can use your AppleID to file the report (even though it is technically for developers). The more that file, the more likely it will be to be noticed.
Old Oct 13, 2017 | 11:52 AM
  #72
CPR's Avatar
CPR
Acura In-Car Tech Team
888 528-7876
Just got off the phone with them; blame game on Apple; no immediate fix
They claim that Apple IS AWARE of the problem; we'll see
Not a MAJOR headache, because, I can utilize Siri, through AcuraLink, to call any of the 200+ #'s in my phone
Just a minor nuisance
Old Oct 13, 2017 | 04:23 PM
  #73
t5620's Avatar
tried that and got no reponse from them
Old Oct 14, 2017 | 02:37 PM
  #74
stevetech74's Avatar
Hi,
I'm having the same phonebook/contacts issue on my 2013 Honda Accord. This all started when I upgraded my iPhone 7 to iOS 11. Now, I'm on 11.0.3 and the issue has not been fixed. What I find most puzzling is, my iPhone 6 works perfectly and it's running iOS 11.0.3. Is the bluetooth hardware different in the iPhone 7? I don't get it. I haven't done a factory reset because, from what I see on this forum, I'm not the only one. I also see it's happening on the iPhone 8. What a pain.
Old Oct 15, 2017 | 07:43 PM
  #75
Darr's Avatar
I have the same issue as everyone else on this thread as far as syncing contacts/phone book is concerned. IOS 11.0.3, iPhone 6s, 2015 Acura MDX Elite package! Apple needs to fix this issue as it was working fine prior to IOS 11 update! I don’t think Acura will update their firmware.
Old Oct 16, 2017 | 03:21 PM
  #76
kgifford916's Avatar
Acura 2018 TLX - handsfree issues
I just got off the phone with Acura there are capability issues with the new 11.0.2 version with Apple Iphone they are working the bugs out with apple and hope to have a fix with the new version.
Main issue: Phone books loads initially then after a minute will drop all contacts.
Old Oct 16, 2017 | 05:01 PM
  #77
t5620's Avatar
iOS 11.1 beta 3 just dropped, can anyone please test if it fix the problem.
Old Oct 16, 2017 | 07:00 PM
  #78
SteelersMike's Avatar
I have the same problems. I updated to IOS 11 and lost my phonebook and voice commands for bluetooth for my 2016 RDX. My lease was up last week and I leased a 2108 RDX. Same problem.
I went to teh Apple store in teh mall and they were no help whatsoever. Acknowledged the issue but had no solution.
Old Oct 17, 2017 | 04:08 PM
  #79
t5620's Avatar
I can confirm that 11.1 beta 3 does not fix the issue. And I think apple will not fix it nor Acura because they don't care
Old Oct 17, 2017 | 04:51 PM
  #80
t5620's Avatar
help raise awareness send feedback to apple here : https://www.apple.com/feedback/
And Acura https://www.acura.com/contact-us here.
