email/text reading?
Old Mar 14, 2015 | 07:33 PM
quintno's Avatar
email/text reading?
I can't seem to get the system to read my text/emails on my new TLX. Car recognized my iphone 6, I'm able to make and receive calls, use SIRI. But I am unable to set up the voice read feature. I've gone into settings, clicked on the "Enable Text/Email" setting--but I am not able to access the "Select Account" or "New Text/Email Alert" features (see attached pic).
Any suggestions?
Old Mar 15, 2015 | 01:39 PM
ZAXDude's Avatar
Any suggestions?
The following previous thread may help: https://acurazine.com/forums/audio-b.../#post15285924
The following may help as well (from a different thread I posted this solution in):
Keifer, do this while not in your car. On your iPhone, access Settings > Bluetooth. Then, for the "HandsFreeLink" device in the list, tap on the "i" within a circle on the right hand side. This will open up a new screen.
On this screen, there should be an item labelled, "Show Notifications". This is likely not enabled for you. Enable it.
Back out of the menus to get to the home screen and then restart your phone. Now go to your car and check to see if the "email and texts" are are still grayed out.
Old Mar 15, 2015 | 06:04 PM
quintno's Avatar
Thanks so much. I did activate the "Show Notifications" and was now able to click on "New Text/Email Alert." However, this is what I got when I clicked on "Select Account" (see photo) which didn't permit me to do anything other than click on it, with no response. And no texts or emails appeared in any form afterwards.
Any suggestions
Old Mar 15, 2015 | 08:36 PM
ZAXDude's Avatar
I would start from square one. Delete device from the car. Forget the pairing from the phone. Turn off phone & back on. Pair. Make sure the "Show Notifications" is set. Then access the "Enable Text/Email".
My best guess...
Old Mar 16, 2015 | 11:18 AM
quintno's Avatar
Unfortunately, just heard back from Acura. Seems my iphone 6 "does not have email messaging compatibility with HFL." Amazing that a phone with this kind of consumer base is not supported, particularly since the Acura has SIRI Eyes Free!
Old Mar 16, 2015 | 01:14 PM
ZAXDude's Avatar
It's known that iPhones won't do the emails. Your OP indicated "...to read my text/emails...". I took that you were having problems with text messages too.
It should read texts fine once set up correctly.
Old Mar 16, 2015 | 01:37 PM
CPR's Avatar
CPR
lol; my BB Q10 gets emails, or txt. msg's, & I downloaded the Android AHA app which works as well
Old Mar 19, 2015 | 01:12 PM
quintno's Avatar
I am now able to get text messages, thanks to ZAXDUDE's instructions. But no email (I guess email is an antiquated technology).
Old Mar 19, 2015 | 01:18 PM
CPR's Avatar
CPR
You have to choose either text msg's, or email; can't do both; you can get email, if you choose to eliminate text msg's, & vice-versa; it's one or the other; not both.
You can switch from one to the other, ONLY when parked!
Old Mar 19, 2015 | 09:31 PM
quintno's Avatar
I tried switching, when parked, but was only able to do TEXT. Wish I could figure out how to make it work, but as noted above, even Acura doesn't believe email will work if using iPhone (they referred me to a manual confirming that fact).
Old Mar 20, 2015 | 08:34 PM
tlxsteve's Avatar
I never did get email to work, but texting worked from day 1 when I paired my Android phone.
Old Mar 21, 2015 | 03:27 PM
CheeseyPoofs McNut's Avatar
Siri Eyes Free works great with the iPhone 6 - nice to be able to reply to the message too.
Old Apr 6, 2015 | 11:17 AM
brutustlx's Avatar
Acura TLX 2.4 Tech 9-2014
So I have this set-up in my car and works fine to receive text messages and have it read to me.... here is the but.
It gives me the option to click on a quick reply (there are some auto reply options), yet every time I try it never works.
Any ideas?
Thanks,
B.
Old Apr 6, 2015 | 02:24 PM
weather's Avatar
^^ I had the same problem with my 2013 RDX, it would give me an error that my replied text didn't go but the people to which I sent the text would confirm it was received...Is that also the case?
DO a test with someone you know to confirm...
Old Apr 9, 2015 | 06:17 PM
mapleloaf's Avatar
Any ideas?
Thanks,
B.
For I phones, for whatever reason, the stock replies do not work. However, Siri works great, so stock replies aren't really necessary.
Old Apr 10, 2015 | 04:04 PM
tlxsteve's Avatar
Just got Lollipop on my Android this week. Sticky.
Anyhow, I can now read/send text messages and read emails in the TLX.
With KitKat the Email option was grayed out.
Of course you can't do both at the same time, but switching between the two while parked is easy. I think I will leave it in SMS mode.
Now if I could get pictures to show up on the display when someone calls.
Old Apr 18, 2015 | 01:56 PM
narnia's Avatar
Team SSM Queen
I have an iPhone 6 and I'm able to get texts but can't respond to them. I just had my navi software updated and asked the dealer if there was a fix for the text reply issue. I was told that feature doesn't work with iPhones. Seems weird that you can get them but not reply to them.
Old Apr 18, 2015 | 08:07 PM
a77's Avatar
a77
I couldn't get text replies to work with an Odyssey customer of mine's iPhone 6 either. Meanwhile the galaxy edge won't fully work with Accord when Bluetooth streaming. Music streams but no data and no track jumping from the car's controls. It's a nightmare for all car manufacturers no?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jimmy_D
Oct 7, 2015 11:52 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
