Door light power wire access?
Old May 9, 2023 | 06:11 PM
TLinGB's Avatar
In order to install footwell LED strips, I would like to access the power wire for the door lights under the dash.
Does anyone know where I would find it, and the color?
TIA
Old May 10, 2023 | 05:53 PM
TLinGB's Avatar
There's a plug for that!
Acura has provided a plug just for this application. It is taped to a loom under the kick panels.
It is taped with black tape, and has an empty male plug installed.
Cut the tape, and remove the empty female from the plug.
I happened to have some plug pieces, so soldered and inserted pins in the "false" plug provided. Yellow wire is the positive.
Old May 10, 2023 | 06:04 PM
TLinGB's Avatar
Now I have LED strips in the footwells that light with the courtesy lights, and fade out just like the overhead lights!
Old May 12, 2023 | 08:17 AM
TLinGB's Avatar
With the help of Matt at Idlestopper, I found that what we need to connect to this plug is a "connector". I found that AliExpress has both ends for cheap.
https://campaign.aliexpress.com/wow/..._id=1085100208
Old May 12, 2023 | 12:04 PM
Motorcycle Connectors
Also has connectors!
PDGCLS01
2G CL Problems & Fixes
Jun 1, 2010 10:10 PM
TouringLow
Aug 30, 2009 11:17 PM
starstruckTL
Jun 3, 2008 09:16 PM
