Android Auto Music Periodically Stutters
Old Mar 22, 2019 | 12:02 PM
centflatsx's Avatar
Has anyone else experienced the audio issue in their 18/19 TLX with any music app using Android Auto. It seems to be random. The music briefly stutter or stop like 3 quick times. The cable is not frayed.Running Android Pie on a Pixel 3XL. No issues with my last car which was last week. I just picked the TLX up last Thursday.
Old May 2, 2019 | 09:19 AM
55lattery's Avatar
'18 TLX V6 A-SPEC
I've had the same issue from time to time using Pixel 2XL w/ AA as well. I also sometimes have to completely disconnect the USB cable from the car or the device because Spotify will only play the first few seconds of a song and then pause. Haven't found a solution, factory resetting didn't fix it so I think it's just a workaround. Not the biggest problem though.
Old May 2, 2019 | 10:19 PM
jhb31's Avatar
Originally Posted by 55lattery
'18 TLX V6 A-SPEC
Same issue with mine, happened with samsung note and then pixel. There is no solution apparently. Works fine with bluetooth but when connected via USB the issue is very frequent particularly if you turn the car off and leave the usb cable connected to the phone and then later restart the car. Like you would turn your car up to get gas. It's very annoying. Waze is fine but Spotify fails to reconnect correctly.
Old May 8, 2019 | 08:32 AM
centflatsx's Avatar
'18 TLX V6 A-SPEC
I went to the dealership a couple of weeks ago about the music issue and also the Bluetooth call issue. It should be known that some newer phones have issues with the Bluetooth setup in the TLX. They had no clue on what the issue is about and said it's software and not on Acuras side. I noticed that Bluetooth works fine for calls when the cable is not connected just using the Bluetooth without the cable. Once the cable is connected Bluetooth drops the phone from the car. They were baffled. When using th call features in Android Auto the cars speaker's do not work for the call. Anyway I guess I'll wait and if I have to make a call I'll park somewhere and use the Bluetooth without the cable. I've notified Google as well but this is probably not a widespread enough issue with it being a TLX. It's not the most common car on the road. As for the music stuttering, it's not too bad lately. I noticed with a more recent update to AA it's a bit better but Google screwed up the weather card and it's not showing now. Always something and always will be with tech.
tallLeRoy
3G RDX (2019+)
133
Jan 29, 2021 08:09 AM
mmhouse
22
Oct 20, 2018 07:59 AM
Jamel Laval
Jan 13, 2017 06:10 PM
jimd
Aug 19, 2007 11:47 AM
turbox777
Oct 14, 2002 01:35 PM
