Would this work?
Old Mar 5, 2012 | 06:39 PM
dragonwang's Avatar
Would this work?
I'm not sure if this has been asked before, but if so, I apologize in advance for not using the "search" button.
Would a 20 x 9 +20 with 255/35/20 tires fit my car on all 4 corners? I'll be doing fender rolling (aggressive if required) and dropped with H&R springs.
Thank you guys.
Old Mar 5, 2012 | 08:18 PM
potmilkz's Avatar
thats mildly aggressive considering its +2 on a 20x9
you might have to do some fender shaving.
i would consider doing suspensions first before you move on to wheels..
go with 245 tires all around..
Old Mar 5, 2012 | 08:21 PM
dragonwang's Avatar
It's actually +20 (20mm offset)?
Old Mar 6, 2012 | 02:36 AM
potmilkz's Avatar
sry, yea its +20 forgot to add the zero
but rule of thumb. always get suspensions before you get wheels.. this way you will know what tire and size rim you need to get after a drop.
getting rims first before a drop will only cost you to waste more money if your tires are not tucking the way you want it to.
Old Mar 6, 2012 | 02:38 AM
Edward'TLS's Avatar
6G TLX-S
20x9" wide and +20 offset will push the wheel/tire outside of the fender. It will need some serious fender work.
Old Mar 6, 2012 | 04:57 AM
dragonwang's Avatar
Okay, thanks guys! I'll consider +35 then once I get my springs.
Old Mar 8, 2012 | 05:11 PM
aspecallday's Avatar
if u plan on doing fender work because of your wheels i wouldnt get springs i would get coils just in case you come across issues.With coils you can play with the adjustments you have to do as with springs you are stuck with a specific hight...
Old Mar 8, 2012 | 07:30 PM
dragonwang's Avatar
Yeah, for now I'll stick with springs. Once the oem shocks go, I'll buy coilovers.
mada51589
Jan 9, 2025 04:40 PM
spidermankb
Mar 5, 2019 11:34 AM
acurajj
Sep 19, 2015 03:47 PM
Luis J. Rodriguez
Sep 12, 2015 10:00 PM
ahsm
Sep 9, 2015 08:35 AM
