Lug nuts
Old Mar 15, 2015 | 04:20 PM
Bobby39's Avatar
Lug nuts
Dumb question, but I need new lug nuts as my current one for my 2012 are rusting. What size are they and where can I find them. Thanks
Old Mar 15, 2015 | 09:23 PM
carbonTSEX's Avatar
The Original Shawdy
You want to look for thread pitch 14x1.5. You can buy them from most tire shops and of course online.
Old Mar 16, 2015 | 09:39 PM
BDoggPrelude's Avatar
Assuming you are running the OEM wheels, you will also need ball seat lug nuts, something most shops are not going to stock in a 14x1.5. You can typically find aftermarket sets on eBay for around $30 or so. Just make sure they are ball seat if you are using them with the OEM wheels.
Old Mar 16, 2015 | 11:57 PM
Bobby39's Avatar
Thank you!! Also, what size hub rings would I need for aftermarket 20" wheels on a 2012 tl awd and will the same lugs work?
Old Mar 17, 2015 | 10:53 AM
potmilkz's Avatar
Monster lugs, they are forged and come in our specs
Old Mar 17, 2015 | 02:17 PM
Bobby39's Avatar
And the size would be the same14x1.5? And stock lug nuts aren't good for aftermarket wheels?
Old Mar 17, 2015 | 02:50 PM
^no, because OEM wheels use a ball seat/style lug.
aftermarket wheels have a tapered seat which only tapered lug nuts can fit
Old Mar 18, 2015 | 12:35 AM
Bobby39's Avatar
Sorry to be a pain, but when you say tapered, can you name some types. I just don't want to buy the wrong ones. Would tapered acorn bulge work?
Old Mar 18, 2015 | 10:40 AM
Booya4139's Avatar
i'm using my acorn seated lugs on my stock winter wheels... did it last year with no problem... probably coming off for summer wheels beginning of april but this thread makes me question if there is an issue doing that.
Old Mar 18, 2015 | 10:46 AM
Old Mar 18, 2015 | 10:48 AM
if you use the wrong type; there just wouldnt be enough surface area to hold onto; potentially having them come loose.
Old Mar 18, 2015 | 10:54 AM
potmilkz's Avatar
you should only use oem lugs on stock wheels.. just sayin..
Old Mar 18, 2015 | 12:53 PM
Bobby39's Avatar
So I was looking at my wheels today and I read the back and it states they are Enkei and also has a Honda motors stamped into them. Could they be stock? They are 20" Rims and if I read it correctly, it says j1 as the model.
Old Mar 18, 2015 | 01:17 PM
most honda stock wheels are made by Enkei
Enkei also makes stock wheels for other manufactures as well, infiniti and hyundai come to mind
Old Mar 18, 2015 | 04:30 PM
Bobby39's Avatar
With those 20" wheels, I currently have summer tires on them (245 35zr20 95y), what would be the size for all season tires? Tryed searching the same size and no one has all season tires for that size.
Old Mar 18, 2015 | 05:24 PM
Brock79's Avatar
There are a few all season in those sizes. Continietal DWS are ones that come to mind.
Old Mar 24, 2015 | 01:39 PM
Booya4139's Avatar
After i wore out my vredstein's i went with DWS 255/35/20's... excellent tire
neuronbob
23
Jul 16, 2019 10:48 AM
johnalfa
Oct 31, 2015 12:55 PM
lland
Oct 4, 2015 04:47 PM
MilanoRedDashR
Sep 24, 2015 11:04 PM
NetGnome
Sep 7, 2015 08:33 PM
