Timing Belt
Old Jul 3, 2012 | 03:37 PM
jk616's Avatar
Timing Belt
I have a 2009 TL with 101,000 miles. Do I really need to replace the timing belt just because of miles. I've heard it's more about how ole the belt is than mileage. Would love some advice! Thanks!
Old Jul 4, 2012 | 02:04 AM
farmdog's Avatar
I don't know......but how is your car holding up with those miles?
Old Jul 4, 2012 | 09:56 AM
ejbrandt's Avatar
TL Driver
I would say yes, change it. Do you have a estimated cost.
Old Jul 4, 2012 | 10:35 AM
ShadeTreeMech's Avatar
Timing belts should be replaced after certain amount of time or mileage, whichever comes first. Youve already hit the mileage so replace it soon.
Old Jul 4, 2012 | 10:43 AM
AEmedic's Avatar
Just think, if it fails and it eventually will, a failure destroys your engine. Since you don't know when it will fail, the change interval keeps you from "statistically" pushing the limit.
It isn't worth the risk, not even kind of!
Old Jul 4, 2012 | 12:12 PM
Teddybear's Avatar
Subsonic
that's a lot of miles for a 3-4 yr old car!
Old Jul 4, 2012 | 02:30 PM
Edward'TLS's Avatar
6G TLX-S
Depending on how fast the car is traveling when the timing belt snaps, the damage can range from a couple of belt valve stems all the way to broken piston arms poking out through the expensive engine block.
Old Jul 4, 2012 | 07:06 PM
jk616's Avatar
The car is holding up great...it's mostly highway miles. I've gotten quotes for around $1200. Everyone's on the same page....better now, than have it go and do more damage.
Thanks for all the feedback...will schedule an appt. now
Old Jul 4, 2012 | 07:34 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
has your car asked for the TB to be changed? just change it when it flashes the MID code with an A or B with the "4" to indicate TB service. this can flash somewhere around the 105k mi mark give or take 3k mi.
$1200 is not unreasonable for a dealer price.
it's not like when your car reaches 105k mi the TB snaps. just follow your MID and you'll be fine.
Old Jul 4, 2012 | 07:44 PM
jangkai's Avatar
Yeah get that belt changed ASAP. The recommended interval is 105,000miles, and though I've seen other Hondas that were fine up to 150,000miles (due to the driver not being informed), it is definitely a bad idea to go past the recommended interval.
$1200 seem like a reasonable price. When I had the timing belt and the water pump changed for my parents' Odyssey, it cost $1000.
Old Jul 5, 2012 | 06:31 AM
Pseudomaniac's Avatar
Timing belt, water pump, new sparkplugs, check valve lash, replace engine seals as needed, clean EGR, replace serpentine belt, flush cooling system, change oil, change trans fulid, change differential fluid.
100k maintenance. Religious on Honda.
You go 120k on that belt, it's gonna snap - and you'll be lucky not to stick a valve and be out big bucks.
My Honda mechanic friend does this work on the side, it's a flat $700 to have it all done, parts included. Likely similar offers in your area.
Old Jul 10, 2012 | 08:10 AM
bmwr1200c's Avatar
Man where do you live, I would not mind driving my car from ohio to get to your place to get all these changed for $700 bucks
vaughanml2
Nov 1, 2021 10:16 AM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
merc009
Sep 14, 2015 06:43 PM
asahrts
Sep 4, 2015 05:55 PM
