Static Noise Issue
Old Feb 22, 2020 | 04:10 PM
j22patel's Avatar
5th Gear
Static Noise Issue
Hi...I have Acura 2012 SH-AWD...since last 4 weeks, I am noticing that as soon as car reaches around 110-120 km/h, the static noise start coming somewhere front the front of the passenger side...this noise will go away as soon as I am below 110-100 km/h...I went to a regular mechanic but he could not find where the noise is coming from...Has anyone else experience same? Any comment will be appreciated.
Thank you
Old Feb 23, 2020 | 04:08 PM
_Itachi_'s Avatar
8th Gear
Is it coming from the engine bay? Have someone else sit in that passenger seat and do them where it counts like it’s coming from. Maybe your have a loose muffler strap, it could be anything. Unfortunately this is probably a scenario you’ll have to do some research on by opening your engine bay and just checking everything making sure nothing is loose, even check the plastic cover under the car that protects the transmission and steering rack.
Old Feb 27, 2020 | 06:59 PM
j22patel's Avatar
5th Gear
@_Itachi_...thank you very much for your reply...I will give it try soon and update...
Old Sep 17, 2020 | 09:22 PM
mmerle's Avatar
4th Gear
@j22patel Did you find a solution to this? Having the exact same issue.
Old Sep 18, 2020 | 12:11 PM
echodigital's Avatar
From TL to RDX
If this is like a whistling type of noise, it maybe a propellor shaft issue. I had mine replaced under warranty (2009 TL - replaced part in 2011). This sound seems like it came from front passenger area which is odd.
Old Sep 18, 2020 | 12:22 PM
mmerle's Avatar
4th Gear
@echodigital It's not a whistling type noise, it's purely static sometimes crackles a bit. I initially thought I blew out my speaker but it happens even when the sound system is off. Like the original post said it only happens at higher speeds or when the cars under load. I'm thinking it may be ground looping.
Old Sep 18, 2020 | 12:39 PM
j22patel's Avatar
5th Gear
mmerle
After so many trial and error, I found out that the black seal on the trim was loose so due to wind at high speed it will vibrate, which will create static noise...I just applied some glue to the black seal and the problem is gone for good...it costed me $1.00 glue...
regards
Old Sep 18, 2020 | 12:48 PM
mmerle's Avatar
4th Gear
@j22patel Are you talking about the black seal under the chrome trim? Thank's a lot saved me lots of troubleshooting!
Old Sep 18, 2020 | 01:05 PM
j22patel's Avatar
5th Gear
Yes, that’s the one. When the car is not moving, it’s hard to notice that it’s loose because it’s so thin. It will take lots of wind force to vibrate. Have someone sit in the passenger side while driving on highway at around 120km/h, open the passenger side window and have him put his hand around the chrome trim. That’s how I figured out that the rubber seal is loose and that’s making the noise.
regards
Old Sep 18, 2020 | 01:07 PM
mmerle's Avatar
4th Gear
Perfect, thanks again!
Old Sep 18, 2020 | 01:09 PM
j22patel's Avatar
5th Gear
You are welcome...please let us know your findings...
regards
joe424242
3G RDX Problems & Fixes
Apr 1, 2019 08:54 AM
PocahontaS007_typeS
Apr 17, 2016 08:46 PM
highgrade
Oct 18, 2013 10:20 AM
Dre327
4G TL Problems & Fixes
14
May 22, 2012 07:07 AM
