Rust on rotor hub-2010 TL
Old Mar 9, 2011 | 11:51 AM
rafiki121's Avatar
I saw on a previous post that on the 2010 tls they fixed the rust problem on the rotors. Basically i noticed today that my car had rust on the rotor hub and i was wondering since it was suppose to be fixed on the 2010 tls (if thats true) can i have the dealer clean it up and spray paint it for me
Old Mar 9, 2011 | 11:54 AM
renedcruz's Avatar
'That's what she said!'
OEM rotors seem to have that problem no matter which Acura you have. The best thing to do is get aftermarket rotors (stoptech, racingbrake, etc.), which have a protective coating that does not allow rust to occur on your rotor hub.
Old Mar 9, 2011 | 02:00 PM
Bearcat94's Avatar
AZ Community Team
Or get a Dupicolor brake caliper paint kit and paint 'em. Paint calipers (if you want) rotor hubs and rotor edges. Pretty easy and pretty effective.
Old Mar 9, 2011 | 02:11 PM
Smoothie97's Avatar
I get rust every time the rotors get wet, especially when I wash my car. The remedy is easy. Go drive your car for one block and apply the brakes several times (light and hard braking). When you return, the rust is gone (and won't come back, until they get wet again).
Old Mar 9, 2011 | 04:19 PM
Bearcat94's Avatar
AZ Community Team
Works for the swept area, not the hub though.
Old Mar 18, 2011 | 05:28 PM
acuratech1's Avatar
guys.... every car no matter what manufacture you have gets rust build up on the hub/brake rotors
Old Mar 7, 2017 | 03:50 PM
mrphilipanderson's Avatar
Are there no shops that does this as a service? Cant I pay someone to do this for me?
I dont wanna have to take my wheel off. Theres no spray that doesnt require wheel removal?
I dont have a level space to jack my car up,
Old Mar 7, 2017 | 03:52 PM
Take it easy on bumping all the old threads that talk about rust on rotors.. yore going to miss answers to your questions
it's absolutely normal. You either live with it. Or replace the rotors . It's purely aesthetic and doesn't affect performance.
Old Mar 7, 2017 | 05:16 PM
jim_c's Avatar
I stumbled across a simple fix for this problem of rust on the center part of the rotors on my 2010 TL. This has worked amazingly well.
Clean off the rust by lightly sanding; you don't need to get it 100% perfect.
Then smear a light coating of silver anti-seize grease around the area that tends to rust.
Obviously you don't want to get this on the surface of the rotor that provides the pad contact.
Try it and see for yourself. Experiment your way into it if you are skeptical.
Skeptical is good.
You will thank me.
J.
Old Mar 10, 2017 | 03:39 PM
echodigital's Avatar
From TL to RDX
Just get them painted. When I had my caliper's painted black, they just sprayed the hubs black as well.
Old Apr 14, 2017 | 12:37 PM
jim_c's Avatar
Oh. OK.
Old Apr 14, 2017 | 12:44 PM
Acura thought I was crazy to expect the rust on my rotors to be their responsibility.
So how on earth did you guys get the dealer to paint them FOR YOU? Im not comfortable doing it myself as i dont own the proper tools, abd Every autobody place i visit stops me before I even finish satying YOU CANT PAINT ROTORS! What the hell?
Old Apr 14, 2017 | 12:46 PM
How can bumping an old thread (that never resolved the original issue) make me miss the solution? I bumped it in pursuit of a solution. Perhaps someone RECENTLY had the issue and fixed it.
Old Apr 14, 2017 | 12:50 PM
Probably because you're asking to paint the whole rotor and not just the hub area.
Old Apr 15, 2017 | 11:29 AM
ANyone with the tinitest knowledge of cars would know you cant paint the part that touches the pad. Obviously I meant the parts that do not contact the pad. IM just gonna go after market.
Old Apr 15, 2017 | 12:01 PM
Blaze9's Avatar
Well you can paint the rotors all you want, go drive down the block and the paint'll be gone. I mean you don't need to do anything special to paint your stock rotors. Take them off, mask off the rotor, and get high temp spray paint. You can use the ones made for calipers or ovens or whatever it says on the bottle as long as it's high temp.
Old Apr 16, 2017 | 10:57 AM
Tonyware's Avatar
'20 TLX SH-AWD A-Spec
Sand it well and use a primer before the heat paint. One or two light coats of this... or something similar.
Rust Check Rust Killer | Canadian Tire
... with enough drying time inbetween coats. Then coat it with something like VHT high temperature caliper paint. Five years later and no rust on the rotor hubs.
Wear a mask and eye protection. The sanding and painting is deadly shit.
Do not paint the rotor surface itself !!! It is normal for humidity or rain to cause some rust on the rotor surface, especially if you leave the car parked for a while. It goes away after you drive. If you are so picky, well, get some cloth and wipe off the rust with some brake cleaner spray. But do not paint the surface where it touches the pads !! That is the worse thing you can do to your brakes and if you do I am sure some mechanic will think you are as intelligent as a door knob !
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
lanechanger
Oct 13, 2015 10:56 AM
polish_pat
Sep 30, 2015 12:22 PM
