Removing "A" Pillar garnish?
Old Apr 28, 2010 | 07:22 PM
SSGHutch's Avatar
I've exhausted all means and patience trying to safely remove my A pillar interior garnish in order to change my factory tweeters. There seems to be some sort of strong clip at the top and I don't want to damage the clip or pillar garnish. Any help or insight would be greatly appreciated.
Old Apr 29, 2010 | 06:06 AM
Sugi's Avatar
When I had the dealer replace the tweeter, under warantee. They ordered the tweeter but did not order the clip (s). As a result, I had to go back a second time get it done. The service tech said that it is more than probable that he would break the clip when taking the pillar trim off. I dont think these parts a very expensive. I would recommend ordering the clips and then install the speaker. Check out bernardi parts to see the part numbers as below.
014
018
91560-SLJ-J01
View
CLIP, DOOR LINING (LIGHT GRAY)
0.28
0.21
0.00
004
019
91561-TA0-A11
View
CLIP, RR. PILLAR GARNISH
2.80
2.10
0.00
Old May 1, 2010 | 03:37 PM
kotomoto's Avatar
dont pull out on the a-pillar u actually have to hit it with a rubber hammer exactly where the "" side air bag "" logo is there's a crushable clip behind it and it's a one time use clip that u have to replace it after removing it
Old May 1, 2010 | 11:13 PM
SSGHutch's Avatar
Thanks for all the help, looks like I'm ordering clips.
Old May 1, 2010 | 11:28 PM
SSGHutch's Avatar
Just ordered the clips, I'll let you guys know how it goes, thanks for the help. I actually tried to find the clips on the honda estore before starting this thread but had no luck in finding the part numbers.
Old Feb 29, 2012 | 06:21 PM
Samba's Avatar
Hi SSGHutch,
I am going to hardwire a dash cam in my 4th Gen TL. Can you describe the steps to remove it? Where were the clips, etc? Thanks.
Samba
Old Feb 29, 2012 | 11:05 PM
Edward'TLS's Avatar
6G TLX-S
If you pull back the rubber seal along the top of the A-pillar, you'll see a notch or indent on the edge of the metal body frame. This marking shows where the breakable clip is located near the top of the A-pillar.
You'll need a rubber hammer to hit the A-pillar, directly on the breakable clip, so as to break apart the clip and release the top portion of the A-pillar. You'll have to buy a new clip in order to reinstall the A-pillar properly.
There's another clip near the middle/bottom of the A-pillar. This one you can just pull out and reuse.
Old Mar 1, 2012 | 11:10 PM
Edward'TLS's Avatar
6G TLX-S
Sorry, my mistake.
The marking tab is on the top edge of the A-pillar cover itself, not on the metal frame like I said earlier.
mlody
Dec 4, 2019 02:11 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
InFaMouSLink
Oct 27, 2015 06:52 PM
dainmezron
Oct 16, 2015 06:56 PM
lowgrowl
Sep 26, 2015 05:18 PM
