Advice On Stripped Screw Hole
Old Mar 1, 2012 | 06:28 PM
dyrtyred's Avatar
When changing a gasket on my j pipe to fix a leak, a stud from the exhaust manifold stripped out of the hole. I found a replacement stud but I also need the hole tapped out. Any ideas how much the dealer would charge to tap out the hole?
Old Mar 1, 2012 | 06:38 PM
potmilkz's Avatar
use a drill and drill the center out, it should slowly crack into pieces.
but the bigger question is.. are those 21's on your ride?
Old Mar 1, 2012 | 06:45 PM
dyrtyred's Avatar
The stud is out. It's the hole that it threads into that's stripped. Nope they are 20"s
Old Mar 2, 2012 | 12:28 AM
AzNTLBoI37's Avatar
9th Gear
I would say go to the auto parts store or Sear if you have one there and get the MM tip kit and just tap it from a m12 to m14 or something like that and get that size bolt and the same length and a lock washer and you be good to go. so i hope that help you out.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
