Rear Windows fogging
Old Jan 16, 2012 | 09:04 AM
bmwr1200c's Avatar
I live in North East and during the winter time when two or more people are traveling both rear windows get fogged up. Am I doing something wrong for this to happen.
When I run the defrost then usually i clears up front glass and two front windows, but not the rear one.
Any help would be appreciated.
+++ 2011 Acura TL Tech Pkg
Old Jan 16, 2012 | 10:20 AM
Pseudomaniac's Avatar
Oh come on, that's your excuse for fogging up the rear windows?
there's two defrost buttons, one for front, and one for rear (sure, it's obvious, but making sure) as the rear defogger works great in mine.
Tried popping the moonroof open to equalize the temperature/humidity in a crunch?
Old Jan 16, 2012 | 10:38 AM
potmilkz's Avatar
Old Jan 16, 2012 | 10:50 AM
eazy's Avatar
WDP 4G
Wait til you get to the hotel bro..
jk but yes there are 2 defog options. one for front windshield one for rear. the rear one should be right under the front defog
Old Jan 16, 2012 | 11:41 AM
Mr Marco's Avatar
Have you checked the fuse and relay for the rear defogger?
Old Jan 16, 2012 | 12:45 PM
Teddybear's Avatar
Subsonic
i think the OP meant the 2 rear side windows. i have that issue when ppl are in the back sometimes.
OP, i just point the vents at the front to blow air towards the back of the car. the only solution is to make sure air gets back there.
Old Jan 16, 2012 | 12:53 PM
potmilkz's Avatar
his question leaves us guessing on many different scenarios..
maybe body heat?
Old Jan 17, 2012 | 12:38 AM
Edward'TLS's Avatar
6G TLX-S
The front defrost button will clear up the front windshield and the 2 front side-windows.
The rear defrost button will only clear up the rear windshield.
There is nothing to clear up the 2 rear side-windows, other than lower them down full.
Old Jan 17, 2012 | 07:45 AM
bmwr1200c's Avatar
Smile
Thanks for all your replies, as I said when two people are travelling ( or Driving),
I mean there should be some setting to clear up the two rear door windows not the rear windshield. I am not complaining but checking if other people faced similar situation and whats sort of solution. As far as the 2011 TL, the car runs great there are not issues with it.
Old Jan 17, 2012 | 09:38 AM
Teddybear's Avatar
Subsonic
fastest way is to crack open the windows.
slower way is to just point the vents at the front towards the back. it does get rid of the fogging, but it's slow.
i havnt found any other solution. u could try some anti fog spray?
Old Jan 17, 2012 | 10:20 AM
Acura2010's Avatar
Use the "Automatic" climate control. The A/C will act as a Dehumidifier, and will keep your windows clear. I've not had any issues with fogging in my car, but i also am always using the Auto Climate control.
Old Jan 19, 2012 | 09:24 AM
bmwr1200c's Avatar
Pardon my ignorance, I am new to TL. There is a auto button on top of driver side temp adjustment. When I press that a auto text shows up on the dashboard display. Is that what you mean when you said put the system in auto.
Old Jan 20, 2012 | 01:29 PM
Acura2010's Avatar
Yup, that's exactly what i mean, the Auto button is the Automatic Climate Control. It will turn on and off your A/C when needed, you won't even know what it's doing, but it maintains temp and humidity levels in your car.
Old Jan 23, 2012 | 06:49 PM
Eli's Avatar
Eli
+1 for the Auto setting. If you just let it do its thing, its programmed with good logic and does a good job regulating the temperature and keeping the interior dry to prevent fogging. I haven't touched the climate controls since I bought the car 3 years ago through winter and summer.
oyayjoe
Jan 1, 2019 10:17 PM
HOWELLiNC
3G TL Photograph Gallery
24
Oct 8, 2015 03:15 PM
oyayjoe
Sep 12, 2015 04:40 PM
EE4Life
Sep 11, 2015 10:13 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
