Limp mode and loss of power
Old Dec 5, 2013 | 03:50 PM
probmxstyle's Avatar
Odd thing happened on my way home today. While accelerating onto an on ramp in 3rd gear, I noticed the car was unresponsive to the gas pedal. It was just stuck at 3k rpm's. Prodding the gas pedal did nothing. I down shifted, which seemed to fix the issue. No Lights on the dash lit up. I have a 2012 6 sipped with 15k miles and use 93 octane.
Old Dec 5, 2013 | 06:58 PM
Took the car out later tonight and everything seems ok. Could it have been just an electrical hiccup?
Old Dec 5, 2013 | 07:17 PM
Art unique's Avatar
When was your last oil change? Check your dipstick for low oil
Old Dec 6, 2013 | 12:40 AM
Jackieee_TL's Avatar
How much gas did you have left? Also was it a sharp round loop on-ramp? If so, then gas could of shifted, and fuel pump ran dry for a second or two (car bogs).
Old Dec 6, 2013 | 05:05 AM
Oil is fine, it's a hair under the max mark.
I have just under a half a tank.
Old Dec 6, 2013 | 08:12 PM
JM2010 SH-AWD's Avatar
Weird. Probably what you suggest, an electrical hiccup. What sort of shape is your battery in?
I wouldn't worry about it, but watch to see if there's a recurrence.
Old Dec 11, 2013 | 01:35 AM
ac011's Avatar
Do the check engine light on?
Old Jan 24, 2014 | 11:51 AM
*UPDATE*
So this happened again the other day. What is odd is that it happened in the same spot on the road as the last time. I was drifting up to a traffic circle, came to a stop, then accelerated. When I shifted from 1st to 2nd, I lost all engine power. The RPM's did not drop and the engine did not stall. It felt as if the gas pedal was unplugged. Again, I prodded the gas pedal a few times and everything came back to normal. No check engine or any other lights.
Old Jan 24, 2014 | 01:02 PM
ucf_bronco's Avatar
I think this same thing happened to me a while back. I had actually forgot about it until reading this thread. I don't remember the specifics but I'm pretty sure it was very similar to your story. It hasn't happened since and that was a while ago, but it's interesting that it happened to someone else too.
Old Jan 24, 2014 | 01:31 PM
I actually submitted a complaint on the NHSTA website about it. The most recent complain on their page for the 2012 is actually for the same issue. I recommend you also submit a complaint. If there are enough, they may look into it.
Old Jan 27, 2014 | 03:07 PM
gibbyisgibby's Avatar
When i experienced that problem with a vw it was a MAF sensor.
Hope it doesnt come back!
Old Feb 12, 2014 | 03:57 PM
php007's Avatar
This has happened to me as well during a sharp right turn. I try to accelarate coming out of the turn and no power for a second.
Old Feb 12, 2014 | 04:01 PM
php007's Avatar
Forgot to add that it's a 2009 TL SH-AWD with 66K miles on it.
Old Feb 12, 2014 | 08:06 PM
Mine happened during a right turn as well. So weird...
Old Feb 13, 2014 | 11:51 AM
ABDomega's Avatar
2011 SH-AWD 6MT
Have you guys tried to simulate problem with TCS deactivated?
Jul 16, 2017 07:33 AM
hashbrown
Sep 29, 2015 12:13 PM
Rcelestino93
Sep 23, 2015 10:01 PM
