Cylinder 5-zero compression. 2009 TL.....Help
Hi TL Owners.
Any advice will be appreciated..
68000 miles..2009 tl..while I was driving on a highway
suddenly I got misfire code from check engine light..code was cylinder
3 & 5..misfire.After taking to local mechanic shop he told me cylinder 5 has
zero compression..after compression test and plug swap..so he told me to
take it to dealer to check..Now 2nd day at dealer.They couldn't figure it out
with computer diagnostic. So they said they have to take the engine out.
any idea what can be wrong? service guy is not sure if these are covered by
warranty. if it's my fault..I am paying about $1000 for just a
diagnostic test.
Also TCS/abs LIGHT CAME ON AFTER I REPLACED BRAKE PADS FRONT / BACK.
is this related to same issue? or that's related to replacing brake pads?
I am a highway driver 90 miles a day.
I put super only and mobil 1 oil only because the long range.
I am not a abuser of the car either...
any advice or comment are really helpful..thank you guys.
diagnostic test.
Last edited by salbal106; Jan 7, 2014 at 10:13 PM. Reason: forgot to put other info
Random multiple misfire can be caused by several things,eg dirty or damaged MAF sensor,bad gas,dirty throttle body,EGR valve,bad coil pack etc. However,those will not cause a loss of compression.
In your case i suspect that you may have an issue with the cylinder head intake/exhaust valve,it could be that one is bent,not seated properly or burnt.If it is a valve issue then the mechanic need to check for the underlying issue that caused the failure,unless it is a defective valve then simply replacing it will only be a temporary fix.Worst case scenario,valve issues can also cause piston damage,lets hope it is not that bad.
Please keep us updated and post how the issue is resolved.
Thanks for your advice.
Today is third day at dealer..Still got a loaner car..
I guess they still haven't found the problem.
you're advice is close to what my mechanic said..
do you think these are my cause? or mechanical cause?
I am in 50/50 situation for paying bills or cover by warranty.
thanks. again.. I will keep updated..
You are welcome,the brake work that was done to your car has no connection to your current issue. I am doubtful that you had anything to cause this problem, some of the things you have to be mindful of are, was oil level low, too high? Did you run it low on coolant? Did you get bad gas? Etc.
What caused the problem will be much more difficult to find than to diagnose the problem, more than likely they will remove the cylinder head and examine the valve train, they will also look at your pistons and engine block.
Is your car the Sh ?
Wish you well and I hope the damage is not too severe.
doing compression test..I lefted a car there for over 3-4 hours.
68000 miles..that was my first time changing brake pads..90% highway.
Far as oil change I had 40% left on my indicator..mobil 1 I use.
even gas.. I put super only..
dealer is doing exactly what you are saying checking pistons & engine block.
My tl is not SH..its' base with tech/package.
Also, Should I tell them to have check all the service bulletin regarding 09 tl?
I was the one, mention about speaker rattling. Now it's on service bulletin.
back then, dealer guy thought I was weird guy..they said they found no
problem...I have same color as your TL but doesn't look nice as yours.
I was about to get new rims but this thing happened...
thanks for your concern..I will keep you updated.
finally, dealer called..
cylinder is burned...due to bad gasoline..that's what service guy said..
he recommand it TOP TIER GASOLINE company..
not the one I use. which is SUNOCO.
I have been sunoco customer since 2005 OMG..
EVERYWEEK I PUT 18 GALLLONS..THIS IS THE RESULT..
luckly, dealer is covering under warranty..I can goto sleep now..
thanks for you help and advice, especially, karkraze
Happy to hear that it is being covered by the warranty and to hear that all is working out well.
recommended.
OP,which grade gas did you purchase from Sunoco?
I should also mention that only the Ultra 94 is top tier.
Suncor Energy Inc (Sunoco) merged with Petro Canada and now only Petro Canada offers the Ultra 94. The other grades are not top tier and are offered through Husky stations in Ontario Canada.
http://www.toptiergas.com/retailers.html
looks like petro 94 is good.
I can tell you one thing...I have been using sunoco ultra for long long time.
because of the location where I work..and plus sunoco is little
cheaper than other brands.. Now.I have to change it..
I am reading the warranty manual..it's powertrain limited warranty.
cylinder block and head all all internal parts. and more..
I am very lucky that I didn't exceed 70000 miles. I had 68500 miles.
Do you really think Gasoline really made my cylinder to burned?
93..Ultra..
High grade gas contains a higher level of detergent to help prevent the build up of carbon deposits.
Thank you for keeping us informed.
Sounded a little fishy to me, too. I would have a look at the injector for that cylinder. Unless you are going to make the case that low(er) detergent gasoline may have caused the injector to clog, it seems like a stretch to blame the gasoline. Lean mixture from a malfunctioning injector would cause that cylinder to "burn".
It will be interesting to see if any of the other cylinders show the same sort of symptoms. If so, then I guess it could be the gasoline.
do you see the big damage? I can't really tell..
If the valve came apart while cruising down the highway, IMHO that would have to be violent detonation in that cylinder or a faulty valve. Once again, the injector could be at fault, but...hmmmm..As long as they are fixing it under warranty then ok. If they rebuild/replace that head, then I'd be sure to ask for new injectors. If you get a crate motor, then all should be good.
I'm having the exact same issues with my vehicle and I am now 1 week in to the problem. Took to Acura dealer, have an extended warranty, as the car was CPO with about 7,000 miles on it at purchase. Now have 90,000 (do alot of highway driving). Acura diagnosed the issue as needing a valve adjustment, new spark plugs, and a top engine cleaning (fuel injection service). Wanted 1,200 to do the work. Said that this was all a "maintenance issue" and that it was not covered under my warranty that runs out at 100,000 miles. Took the vechicle to a certified mechanic (a friend) who did what Acura diagnosed for around 600 bucks. Did the work, problem still occuring. He finally found the problem to be 2 bad fuel injectors. Would these injectors be covered under warranty?
As mentioned before, direct injection can have these issues due to prolonged use of lower grade gas. Do an internet search on carbon deposits and direct injection engines/ walnut blasts etc.
^^ somehow part of my post did not go through.
Our engines have port injection and should not have the issue as direction injection, "Slithr" may be on point when he said that it could be a faulty injector that led to your problem.
Yes there is damage to the valve, if that piece was in the block the your damage would have been extensive ie broken piston and scored block due to contact.
Which engine is this? 3.5 or 3.7? This is the first I am seeing broken valve at this mileage on a Honda. Obviously, dealer is just blowing smoke by blaming it on the "bad gas". The only explanation is that Honda got some bad batch of the exhaust valves aka manufacturing defect.
Lucky for him it crapped out under warranty.
Glad to hear they are covering it for you.
Without knowing more about your car's history it is hard to say for sure but nobody has mentioned the most probable cause of the OP's problem.
The most likely cause it seems to me is that the valve train was adjusted too snug, i.e. there was not enough "valve lash" or clearance.
Was the valvetrain ever adjusted?
The Acura V6 has a fair amount of valve clatter when it is properly set up. The valve clearance has to be set so that the valves seat full in the head when they close. This is how they are cooled - by conduction of the heat from the valves out through the heads. If the valves do not seat properly (because they were set to be very quiet) then they will overheat and burn. I bet you have more problems (OP) with the valves at the other cylinders, not just the worst one.
Hey acuraboriqua - why are you quoting my post?
Your post has nothing to do with my post.
Wheras my post makes sense, yours is complete nonsense!
Water does not flote nor float on gasoline.
The specific gravity of gasoline is about 0.75.
Some interesting thoughts. I thought, and I could be wrong, that these engines had hydraulic valve lash adjustment. Could it be that the adjuster may have failed in some fashion and that could have caused the valve to hang open a little and burn? Just making stuff up.
Glad dealer fixed for you...since they did fix it, I guess this thread has become a discussion on as to how/why the cylinder took a crap. So, here's my take...
"Bad gas"...I've heard of it, but honestly...only way you're going to get "bad gas" is from water in the station's holding well/tank or dirt/grit in it. Like someone stated earlier, it looks like water in your fuel, dirt/grit would have taken your fuel pump out first or clogged the fuel filter first.
Water would explain the heat in the cylinder to ramp up to CHAR that valve, making it brittle and weak...SNAP...and also, like someone said, exhaust port, it blew right out.
I surely hope they bench tested that injector or replaced it, because it is MOST LIKELY damaged due to the water, rusted inside and even sticking or even stuck.
quanaman
Jan 9, 2023 07:33 PM
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
joflewbyu2
Oct 8, 2015 11:16 AM
