Intermittent A/C Issue - Please Help
Old 06-16-2016 | 12:28 PM
wmahmud's Avatar
Over the past year my A/C has been hit or miss..sometimes I can feel the cold air coming fine..and sometimes it will become just the fan...
Acura did a evacuation dye and recharge and found no leak...but I still notice the issue...
Odd is when I am accelerating..its as if the fan kicks in...when I am driving extremely slow or brake or come to a stop... the cold A/C kicks in intermittently..and sometimes goes back to fan air only...
Any ideas where I should look at next ? Apparently Acura checked the fuse as well
I'm lost
Old 06-22-2016 | 09:21 PM
dwest1023's Avatar
I'm lost
Sounds like you have some sort of restriction in your ac system. AC gauges showed show this.
Old 06-29-2016 | 11:31 PM
Cooldude01's Avatar
Did you figure out what's wrong?
It seems like my 2012 TL starts to have a similar problem too..
Old 06-30-2016 | 10:05 PM
JasonK's Avatar
09 TL SH AWD /w TECH
AC compressor
Old 07-02-2016 | 10:07 AM
Reorge's Avatar
Someone else had a pressure switch problem.
Link: https://acurazine.com/forums/4g-tl-problems-fixes-297/air-conditioning-experts-please-step-946806/
Old 07-06-2016 | 10:30 AM
DidiBob's Avatar
How about your internal temp sensors? Mine just came back with cleaned sensors and all is good.
couldn't believe it....but we're ice cold and its 90 degrees outside
Old 07-06-2016 | 09:58 PM
Reorge's Avatar
Also, something to check .... My ex's Honda Odyssey (similar design) had some front end repair work done and the A/C didn't work right after. Finally I saw they forgot to plug in the temp sensor behind the front bumper. Plugged it in and everything worked just fine.
Old 07-07-2016 | 12:52 AM
csmeance's Avatar
I'm lost
Could be a failing A/C relay, or it could be an issue with the pressure valve inside the A/C that allows cold low pressure refrigerant into the system and keeps the hot, high pressure stuff out.
PRNole47
12-27-2016 10:52 PM
RCpilot
08-01-2016 10:32 AM
unnamedny
ILX
18
05-09-2016 09:19 AM
ericcdong
04-01-2016 09:58 AM
Larry1030
03-11-2016 09:27 PM
