Air conditioning experts, please step in...
Old Jun 23, 2016 | 08:23 AM
1Lieutenant's Avatar
Hi all,
Having an intermittent problem with the air conditioning in my 2012 Acura TL. Hoping someone has seen this before and has had it fixed.
The air conditioner will work fine for days then suddenly will stop cooling. The air starts to get warmer through the vents. Still blowing strong. Sometimes turning off the air conditioner and then turning it back on results in return of cooling. When this happened the last time, I turned the automatic temperature control up to 70 from 66 where it was and cooling started working again. Seems to work OK when I first start the car but then will fail (sometimes) after the car has been running for a while.
About two weeks ago the compressor clutch relay was replaced at the dealer and for two weeks there were no problems. Dissection of the old relay showed pitted and burned contacts. The dealer had run diagnostics and no electronic faults were found. Refrigerant pressures/levels were OK
So, what are your thoughts?
1. Defective relay? seems unlikely. Used and original part.
2. Internal temperature sensor malfunction
3. Outside ambient temperature sensor malfunction
4. Compressor clutch
Going into the dealer in two days. Would prefer not to get hosed.
Thanks!
4. Something more expensive.
Old Jun 28, 2016 | 09:00 AM
Update.
Acura tech drove the car until the problem developed. Diagnosis revealed failed high pressure sensor. Part on order. Will require evacuation and recharge to replace. Hope this works.
gavriil
Apr 1, 2026 12:45 PM
emanon256
Mar 9, 2025 06:47 PM
