How do I remove the center console Shifter?
Old Jun 5, 2016 | 12:43 AM
Blaze9's Avatar
Hey all,
I've got as far as removing the two side strips on my 2012 Acura TL, and I've exposed and removed the two screws holding the center console to the main body. I've also removed all the clips, but now the only thing that's keeping me from removing the console is the shifter. I'm not sure how to go about removing this part in order to remove my whole console.
Thanks!!
Old Jun 5, 2016 | 01:29 AM
csmeance's Avatar
Originally Posted by Blaze9
Hey all,
Thanks!!
Old Jun 5, 2016 | 02:14 AM
Blaze9's Avatar
Thank you so much! I just found the 09-10 service manual online =) Perfect info. I'll try that out tonight and see how it goes.
Old Jun 6, 2016 | 09:53 AM
mossman77's Avatar
FYI, the actual shift knob does not need to come off for the A/T model. In fact I'm not sure how it even comes off. I removed the screw on the shaft and tried bending out the tabs but it wouldn't budge. You just have to manipulate the shift panel after releasing it and it will fit downward through the opening so that you can remove the console.
Alex_kamen
2G RDX DIY & FAQ
Sep 18, 2017 10:26 PM
dmaxv8
2G RDX DIY & FAQ
Jun 4, 2016 04:22 PM
therealjgall
May 29, 2016 07:59 PM
Itr0059
Mar 28, 2016 01:06 AM
zexi
Feb 25, 2016 11:36 AM
