Hesitation automatic transmission
Old Feb 18, 2018 | 10:08 PM
Raymond Sanchez's Avatar
Having minor hesitation when in low gears...could.it be I need software update on 2013 TL?? Or do I need transmission flush at 104k miles?? Clunks when shifting to park or from park to drive...
Old Feb 18, 2018 | 10:41 PM
Anicra's Avatar
How many times have you changed the ATF fluid in your car since you bought it? Just curious
Old Feb 18, 2018 | 10:43 PM
I havent since I bought it used a year ago...not sure if previous owner had it done either. I hear it' bad to have a flush completed? What are your thoughts? Any advice will be appreciated
Old Feb 19, 2018 | 07:30 AM
wreak's Avatar
Sounds like it needs the software update and fluid change. The fluid change without software update will likely help the issue but getting both the software and fluid change should completely solve it. Worked for me.
Old Feb 26, 2018 | 10:28 PM
dv-'s Avatar
dv-
It's not bad to do a flush. If you do them regularly, it will extend the life of the transmission.
If you have a failing transmission, doing a flush or a change (they are different) will not fix that. When your transmission fails anyway, people think the service broke it. Usually the explanation from the techs is that the flush/change dislodged gunk and that goofed something up. That's also mostly boloney.
Old Mar 1, 2018 | 10:00 PM
Cooldude01's Avatar
I would contact the dealer first to confirm if you need an update.. that doesn't cost you anything..
The transmission for 4G is extended to 120K miles for 10 years from manufactured date whichever comes first..
Old Jul 14, 2018 | 02:34 PM
cwh82's Avatar
Where can I find document of this extended transmission warranty on 4G TL?
04TL04
Oct 19, 2016 10:27 PM
SnowFlake06TL
Jul 12, 2013 05:04 PM
TL0527
May 16, 2012 03:43 PM
Oct 18, 2001 07:47 PM
Feb 24, 2001 08:49 PM
