Help please! Switchback LED Problem!
Old Jun 10, 2013 | 02:26 AM
mrkwinning's Avatar
Exclamation Help please! Switchback LED Problem!
So I installed everything correctly but the issue I'm facing is that one side or sometimes both after a few miles of driving, it would completely shut off. If I turn the light off then back on, both will come back on like normal. What can this be? I'm so stressed! Been messing with this light issue for over 2 days and have no clue. And yes I have the 6ohm50watt resistors and bought the bulb from DDM Tuning. Any feedback would be great!
2010 TL FWD
Old Jun 10, 2013 | 11:03 AM
potmilkz's Avatar
give details on your leds and how are you wiring these up? are you using clips? or are you just cutting and using black tape?
Old Jun 10, 2013 | 11:37 AM
mrkwinning's Avatar
@potmilkz I'm using DDM Tunings T25-1157-60SMD-White-Amber Switchbacks. I had trouble using the tap clips so I exposed a small section of the wires to make sure the taps connect. The resistors are working bc without them my car was hyper flashing. But after driving it to the gym or whatever, I notice either one or both is turned off and the amber blinker wouldn't even function unless I tran the lights off fully and turn them back on. Is this a power issue? Can it be my HID fog lights I installed that's pulling battery?
Old Jun 10, 2013 | 11:41 AM
Stew4HD's Avatar
Will the lights stay on after you turn on off and back on?
Old Jun 10, 2013 | 12:16 PM
mrkwinning's Avatar
Yes they will. If I turned them off and then back on it will work as normal. White stays on and blinks amber. After driving short distance either 1 or both will turn off and blinker will stop working unless I repeat the process. Weird thing is that even with the lights off, it does not throw any code or hyper flash letting me know the bulb is out. any ideas?
Old Jun 10, 2013 | 02:46 PM
potmilkz's Avatar
you should redo the connection, and move left to right and right to left.. do not use the exposed area you cut off.
it can be various things.. bad led bulb, wiring not making a solid connection, bad resistor..
Old Jun 10, 2013 | 02:53 PM
Stew4HD's Avatar
He does need to make solid connections but what could cause them to work fine after he turns them off then back on? That parts makes it very hard to troubleshoot.
Old Jun 10, 2013 | 03:07 PM
mrkwinning's Avatar
What do you mean by moving it left to right? Switching the resistors around? And why shouldn't I use the exposed wire? Wuoldn't this give it a better connection?
Also would reversing the polarity on the bulb help?
Old Jun 10, 2013 | 03:18 PM
potmilkz's Avatar
its very hard to determine.. but after reading what you had stated.. it seems like it could be a faulty unit..
but as stew said.. its very hard to troubleshoot..
my money is on a bad unit.. but nonetheless, check the wiring, if needed try to make new connections. turn them on and shake the attached wiring to check for any loose connections.
my driver side DRL has been out for a week, havent had time to fix it.. but the car doesnt tell me its out.. its normal.. i just hate it when sellers advertise 50,000 hour life.. and ive only ran a small fraction of those hours.
Old Jun 10, 2013 | 03:31 PM
mrkwinning's Avatar
Would you say both the units on the left and right is faulty? Like I mentioned it's sometimes left or right then both. I will try to troubleshoot tonight. It I cant figure it out then back to stock for good! Beening messing with light issues for over 1 week now.
Old Jun 10, 2013 | 05:04 PM
potmilkz's Avatar
just try to move them left to right to see if they work on both sides.. thats what i do.. test them out on either side for a bit and see if you get the same problem
jblessing
Aug 8, 2018 09:43 PM
TLrascal
Aug 3, 2018 11:00 PM
baowheezy
Sep 22, 2015 09:03 PM
usual.acura
3G MDX (2014-2020)
14
Sep 19, 2015 05:01 PM
Sep 17, 2015 09:01 PM
