Gurgling sound from the rear....
Old Nov 1, 2016 | 10:24 PM
954Rocks's Avatar
I have a 2012 FWD TL that on cool mornings makes this gurgling sound from the rear. It's been doing it for almost as long as I've had the car (original owner). It's not a problem and goes away quickly once I get under way. I notice it at the stop light when leaving my neighborhood and does not return until the next cool morning. Anyone experiencing a similair problem..?
Old Nov 2, 2016 | 12:59 AM
Anicra's Avatar
Fuel Pressure/ bad fuel cap/ check valve / maybe something in EVAP/ maybe something plugged or leaking is the first thing that comes to mind? Any codes coming up on code scanner? (Best guess ATM) Lets see what other people think....
Old Nov 2, 2016 | 03:34 AM
Beak14's Avatar
On the 12-14, the transmission filter has been known to make a gurgling noise. Is that your issue, I don't know.
Old Nov 2, 2016 | 03:31 PM
Lee C's Avatar
I agree mine made that sound I changed the Transmission filter and the sound is gone.
Old Nov 2, 2016 | 08:25 PM
954Rocks's Avatar
I haven't checked for error codes yet. It's weird, it only happens when the cool weather arrives and only is heard at the first stoplight I hit in the morning and doesn't come back until the next morning. Other than that, the car runs great. It doesn't appear to have any impact on performance at this time.
Old Nov 2, 2016 | 08:42 PM
Lee C's Avatar
Hope this helps Good Luck
http://www.urvi.net/forumfiles/SB/B14-049.PDF
Old Nov 2, 2016 | 10:12 PM
dregsfan's Avatar
Is the transmission filter issue just with the original filter, or do replacements develop the same problem? I bought my '13 SH-AWD 3 weeks ago, and I noticed that gurgling sound from the engine compartment and a thread here on the TSB for it, so the dealer replaced the filter today.
Old Nov 2, 2016 | 11:02 PM
Lee C's Avatar
I was wondering the same thing so I just put one of these on.
Magnefine 3/8 Inch Magnetic Inline Transmission Filter
Old Nov 5, 2016 | 02:57 AM
Anicra's Avatar
As the other say, if you hear gurgling and it's near the front then
95pct chance it is the ATF filter Part # 25430-PLR-003 under the battery.
25430-PLR-003 | Acura FILTER (ATF) - Bernardi Parts
If it is truly in the rear then
As always, if you replace the ATF filter make sure you double check your year, just in case it is different, though I think it the same among all TLs.
Old Nov 6, 2016 | 08:42 AM
954Rocks's Avatar
My sincere thanks for everyone input on this issue. After listening CAREFULLY this morning, the noise is definately coming from the engine compartment. I will be taking it in for service with TSB in hand.
Question...... Should the dealer charge me for this TSB issue (my warranty is over I believe. I bought my 2012 TL has an part of Acura's used car warranty in 2013 and believe it only lasted until 65,000 miles..?) ..?
Old Nov 6, 2016 | 08:44 AM
954Rocks's Avatar
Forgot to mention, I have 68,000 on my vehicle now.
Old Jan 3, 2017 | 05:14 PM
Rukkuse's Avatar
I have the same car and same problem. It's done that for me every day since I bought it two years ago from a certified Acura dealer with 12,000 miles. I also bring it in for regular maintenance and the dealer hasn't said anything about it. Therefore I'm assuming it's not hurting anything and is just a minor annoyance when starting the car.
May 20, 2026 01:55 PM
00TL-P3.2
Feb 11, 2019 11:23 AM
TSX69
3G RLX Audio, Bluetooth, Electronics & Navigation
94
Sep 17, 2018 07:45 PM
lowther420
ILX Audio, Bluetooth, Electronics & Navigation
Nov 7, 2016 03:31 PM
Carman3
Jul 16, 2016 02:23 AM
