Gas cap warning light
Old Aug 31, 2023 | 09:17 AM
jjlabarbera's Avatar
6th Gear
Nuisance warnings still appear. Have replaced gas cap and had tested. Have replaced the canister purge valve. Local mechanic also puzzled. Anything else I can try ? 2012 Acura TL Base model no mods.
Old Aug 31, 2023 | 06:07 PM
altair47's Avatar
Which code exactly?
Old Aug 31, 2023 | 06:31 PM
6th Gear
There is no code just the warning message
Old Sep 1, 2023 | 05:32 AM
dvd2012tl's Avatar
Did you review technical service bulletin 11-012 which can be found in the sticky threads above under "technical Service Bulletins" for the 2012 model?
Old Sep 1, 2023 | 10:27 AM
6th Gear
I found the bulletin thank you
Old Sep 6, 2023 | 10:55 AM
6th Gear
Unfortunately this does not apply to our car as our VIN is out of the range of the service bulletin
Acura does not acknowledge it for our car
Our VIN ends in CA023612
Bulletin stops at CA005403
suppose they could try it anyway at our cost
Old Sep 8, 2023 | 06:52 AM
Frankyy's Avatar
2014 TL
can you post the service bulletin I can’t find that one,
when my gas cap light went on the purge valve solved the issue
Old Jan 3, 2024 | 01:53 AM
Lunar448's Avatar
Its in the sticky threads but I'll repost it here. The TSB covers the 2012 TL models only.
https://techinfo.honda.com/rjanisis/...nu/B11-012.PDF
Old Jan 3, 2024 | 11:09 AM
6th Gear
but only for certain VIN numbers see my previous post in this thread
Old Jan 3, 2024 | 11:12 AM
6th Gear
I replaced the purge valve with Dorman but did no good. Bit the bullet and went to dealer who did system check and no leaks. Replaced the purge valve with OEM brand and problem gone for about six months.
But now I getting the emissions code that says I have system leak.
charmer37
Mar 23, 2016 09:53 AM
J2008navTL
Jun 10, 2014 07:10 PM
bmk725
Jul 12, 2011 02:50 PM
anionrings
Jun 23, 2011 10:41 AM
anticd70
Sep 5, 2006 01:01 PM
