Fogs sometimes don't come on
Old Jun 8, 2012 | 02:21 PM
Zelaya's Avatar
2012 TL SH-AWD
Hey guys several days ago I upgraded my fogs to Kaixen 6k on the TL and also change my fuse from 10 to 20 amps instructed by the manual. I've my light set to auto mode and now when the lights turn on sometimes my fogs won't come one so I manually turn the fog off and turn it back on and it works. The funny thing is the andicator fog light stay on my dash but fogs don't. Have someone experience this before? I called Excelerate but they couldn't give me a straight answer. This is annoying
Old Jun 8, 2012 | 02:48 PM
hatepotholez's Avatar
I am not sure if I would change the fuse from 10 amps to 20 amps. If that circuit's wiring is rated for 10 amps it should stay at 10 amps. You probably plugged in your ballast to the end of the connector for the bulb, correct? Also verify the ballast/ignitor is working correctly.
Also can you be more specific on the "straight answer" part?
Old Jun 8, 2012 | 03:02 PM
Zelaya's Avatar
2012 TL SH-AWD
I will go and re use 10 amps for left and right fuse box. No the bulb wire has 4 wires coming out which one goes to oem plug, one to the ballast and other two is black and red wires that connect on color match. What I met to say about straight answer is that guy at Execelerate couldn't tell me a reason why sometimes the fogs turn on auto mode and sometimes don't.
Old Jun 8, 2012 | 03:07 PM
Your wiring after the OE wiring is probably rated at 20 amps but definitely not the OE.
Do you have a picture by any chance?
Old Jun 8, 2012 | 03:17 PM
Zelaya's Avatar
2012 TL SH-AWD
Do you mean pictures of the fogs on or installation? My nephew is a mechanic and told me if I lower the fuse to 10 amps I can burn the ballast, does that make sense.
Old Jun 8, 2012 | 03:24 PM
Pictures of it connected. OE is 10 Amps correct? If so you'll blow the OE wiring if you use 20 amps. Your wiring will smoke first and if continually drawing current might blow the ballast.
Is their a HID kit rated for 10 amps?
Old Jun 8, 2012 | 03:30 PM
gibbyisgibby's Avatar
Ive had this problem for about 6 months. If the car is off and the fogs attempt to come on because of the headlights being in auto mode 1 or none of the fog lights will come on.
If the car is on and i flick them on and off, they will come on. Ive just been living with the problem.
I always thought the voltage wasnt high enough for the HID fogs to come on while the car was off. The fogs were designed for bulbs where the voltage was not such a problem.
Old Jun 8, 2012 | 03:47 PM
Zelaya's Avatar
2012 TL SH-AWD
Unfortunately I didn't take a picture while installing but it's pretty much straight forward plug and play.
Two weeks ago I installed a cheaper hid kit and I didn't have any issues at all except one of the ballast stop working so I ended up returning it back and upgrading to Kaixen to match with my kaixen D2S low bean bulb which is perfect match. I guess I'll just manually turn them on. It's really not a big deal but you figure when you spend $250.00 for a kit it should be flawless.
Old Jun 8, 2012 | 03:53 PM
Zelaya's Avatar
2012 TL SH-AWD
My fogs don't flicker or one comes one.......they either come one at same or nothing so I'd have to manually turn the fogs switch off and turn it back on. What's weird is the fogs would not come on but the fog indicator in the dash will indicate the opposite so the only way I could tell is from the reflection of the car infront of me.
Old Jun 11, 2012 | 07:58 PM
Blueberryyumyum's Avatar
I had this same issue on my Evolution X.. Did you get the 35w or 55w kit? I purchased a 35w kit from DDM and its worked fine (Knock on word)
Old Jun 11, 2012 | 08:19 PM
Zelaya's Avatar
2012 TL SH-AWD
I purchased the 35watts from Kaixen
Old Jun 11, 2012 | 08:22 PM
KB1Spec's Avatar
could be a bad ballast.....
Old Jun 11, 2012 | 08:30 PM
Zelaya's Avatar
2012 TL SH-AWD
They both work at same time but sometime they don't come on when they're set on AUTO mode.
Old Jun 12, 2012 | 03:00 PM
I think you have the same problem as me. Its because when they are set to "auto" they come on before the car
starts, right?
As long as the car is running mine start up fine.
Old Jun 12, 2012 | 03:30 PM
Zelaya's Avatar
2012 TL SH-AWD
starts, right?
That's correct they try to come on but something trigger to turn off once the car starts so I've to manually turn them off and it comes on without no issues.
RLX-Sport Hybrid
3G RLX (2013+)
43
Dec 16, 2015 10:45 PM
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
